Topic: FF800 problems (spanish/english)
Un cordial saludo, escribo con la finalidad de plantear un problema reciente con mi interface de grabacion rme firefice 800, la misma no envia SEÑAL a los monitores, actualice lo drivers y el firmware recientemente, por que crei que ese era el problema, ella esta conectado a una imac por puerto firewire 400 y realmente no se que sucede, la interface enciende, pero no envia audio ni se puede grabar, este fue el drivers que instale recientemente Mac OS X Intel driver for Fireface 400, 800, UCX, UFX, version 3.08. Compatible to OS 10.6 and up, 32/64 bit. This driver requires firmware 1.70 (FF 400) and 2.77 (FF 800) or higher, y este el firmware Mac OS X Intel Flash Update Tool for Fireface 400 andFireface 800. Update to firmware revision 1.71 and 2.77. esperando su pronta respuesta..
Respectfully, I write in order to present a recent problem with my recording interface firefice rm 800, it sends no signal to monitor, update the drivers and firmware recently, because I thought that that was the problem, she is connected to an iMac by firewire port 400 and not really happening, the interface starts, but does not send audio or can be recorded, this was the newly installed drivers that Mac OS X Intel driver for Fireface 400, 800, UCX, UFX, version 3.08. Compatible to OS 10.6 and up, 32/64 bit. This driver Requires firmware 1.70 (FF 400) and 2.77 (FF 800) or higher, and this firmware Intel Mac OS X Flash Update Tool for Fireface 400 andFireface 800. Update to firmware 1.71 and 2.77 review. waiting for your prompt reply .
