Topic: Fireface UCX + 2 Headsets ?
when you want to connect two DT-297 headsets to the Fireface UCX you need two headphone outlets, but there is only one ...
You can get a QuadMic to connect 4 more mics but there seems to be no product to add 5 more headphone outputs?
Is there any other product from another company or so that has the same formfacter and offers a 5x headphone amp? thanks.
Re: Fireface UCX + 2 Headsets ?
Maybe Behringer Amp 800
Georg
I just purchased a Behringer HA400 for this usage. It is in metal, unlike the Amp 800.
3 years warranty (in France) seems trustfully even for B, and it is very cheap. You could even buy several in case one fails.
When I opened it, one pot would crack, but after a few turns it was gone.
If you don't need a *wonderful* quality – for musicians returns for example – it is probably the best portable solution out there.
You can chain two (with losses of course...) if you need more outputs.
But please stay with the UCX headphones output for your mixing/editing monitoring!
