Topic: Total Mix ( HDSPe Mixer) dissapeared OSX
Bonjour,
i searched and couldn´t find a solution...
the mixer window dissappeared, when i changed monitors.
Have tried several ( ignore position / resizing screen / etc ...)
I´m using OSX 10.6.8
Any Ideas? Thank you.
Re: Total Mix ( HDSPe Mixer) dissapeared OSX
Please be more specific.. Does the mixer menu appear? Try hitting I, O, P to see if that will bring back the mixer rows.
Hi Daniel - i did I,O,P didn´t worked, the menu was there but no matrix and no mixer. I searched thru the preferences, but couldn´t find the one for resetting the display
function. load of an old setup didn´t worked as well. Yesterday - i don´t know why, i had the chance to grab a corner of the mixer(wasn´t displayed before) and drag it to the main screen. now it´s working, but i don´t know why. may a reset mode for the windows would be great. i had this error also in the past.
Greetz Tim
I also know this situation, when you finished a session with mixer on a second monitor, shut down computer, go to recording session with only the macbook and the mixer suddenly is out of reach.
That forced me to use software monitoring in LOGIC which also worked very fine.
But the only way I know to get the mixer back is to connect a second screen.
I would be glad if it could be fixed.
UFX+, FireFace 802 FS, Digiface USB
12 Mic, M1610 pro, Micstasy
MacBookPro M1
Logic Pro X
