Topic: FF400 Midi Drivers Crash MidiServer OS X Lion
Received my Thunderbolt to FW adapter in the mail today. I installed FF400 drivers restarted with the soundcard still connected. Opened Ableton Live 8.3.3, no issues, used it for a few hours, quit. Turned off sound card and unplugged it.
Later tried to open Ableton away from the FF400, froze while opening. Opened Console and found out that MidiServer was crashing because of Fireface Midi.plugin. Uninstalled FF400 drivers, AudioMidi Setup started up fine. Ableton starts up fine. Reinstalled drivers, breaks MidiServer again.
I need to be able to use Ableton away from my FF400. Has anyone noticed the same issue with 10.8 Mountain Lion? Maybe I should just update?
Here is the crash report.
Process: MIDIServer [528]
Path: /System/Library/Frameworks/CoreMIDI.framework/Versions/A/MIDIServer
Identifier: MIDIServer
Version: ??? (???)
Code Type: X86-64 (Native)
Parent Process: launchd [123]
PlugIn Path: /Library/Audio/MIDI Drivers/Fireface MIDI.plugin/Contents/MacOS/Fireface MIDI
PlugIn Identifier: Fireface MIDI
PlugIn Version: 3.09 (3.09)
Date/Time: 2012-08-07 00:04:39.980 -0400
OS Version: Mac OS X 10.7.4 (11E2620)
Report Version: 9
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Application Specific Information:
objc[528]: garbage collection is OFF
Assertion failed: (result == kIOReturnSuccess), function FirefaceMIDIDriver, file /Users/martin/Audio/Fireface FW/Fireface MIDI/FirefaceMIDI.cpp, line 571.
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff86517ce2 __pthread_kill + 10
1 libsystem_c.dylib 0x00007fff8af937d2 pthread_kill + 95
2 libsystem_c.dylib 0x00007fff8af84a7a abort + 143
3 libsystem_c.dylib 0x00007fff8afb75de __assert_rtn + 146
4 Fireface MIDI 0x000000010a025100 FirefaceMIDIDriver::FirefaceMIDIDriver() + 388
5 Fireface MIDI 0x000000010a0255b3 NewFirefaceMIDIDriver + 173
6 com.apple.audio.midi.CoreMIDI 0x0000000108c3ab89 XPluginManager::OpenPlugins() + 53
7 com.apple.audio.midi.CoreMIDI 0x0000000108c3427a MIDIDriverMgr::Init2() + 22
8 com.apple.audio.midi.CoreMIDI 0x0000000108c29dec MIDIServerRun + 433
9 MIDIServer 0x0000000108c0ce8e 0x108c0c000 + 3726
10 MIDIServer 0x0000000108c0cdc0 0x108c0c000 + 3520
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff865187e6 kevent + 10
1 libdispatch.dylib 0x00007fff8b43d78a _dispatch_mgr_invoke + 923
2 libdispatch.dylib 0x00007fff8b43c31a _dispatch_mgr_thread + 54
Thread 2:
0 libsystem_kernel.dylib 0x00007fff86518192 __workq_kernreturn + 10
1 libsystem_c.dylib 0x00007fff8af93594 _pthread_wqthread + 758
2 libsystem_c.dylib 0x00007fff8af94b85 start_wqthread + 13
Thread 3:
Thread 4:
0 libsystem_kernel.dylib 0x00007fff86517bca __psynch_cvwait + 10
1 libsystem_c.dylib 0x00007fff8af952a6 _pthread_cond_wait + 890
2 com.apple.audio.midi.CoreMIDI 0x0000000108c21ac3 CAGuard::WaitFor(unsigned long long) + 183
3 com.apple.audio.midi.CoreMIDI 0x0000000108c219f7 CAGuard::WaitUntil(unsigned long long) + 205
4 com.apple.audio.midi.CoreMIDI 0x0000000108c3b716 TimerTaskMgr::Run() + 412
5 com.apple.audio.midi.CoreMIDI 0x0000000108c2296a XThread::RunHelper(void*) + 10
6 com.apple.audio.midi.CoreMIDI 0x0000000108c22396 CAPThread::Entry(CAPThread*) + 98
7 libsystem_c.dylib 0x00007fff8af918bf _pthread_start + 335
8 libsystem_c.dylib 0x00007fff8af94b75 thread_start + 13
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000006 rcx: 0x00007fff6880ba58 rdx: 0x0000000000000000
rdi: 0x0000000000000a07 rsi: 0x0000000000000006 rbp: 0x00007fff6880ba80 rsp: 0x00007fff6880ba58
r8: 0x00007fff7543efb8 r9: 0x000000000000023b r10: 0x00007fff86517d0a r11: 0xffffff80002dad60
r12: 0x000000010a02690a r13: 0x0000000108cff000 r14: 0x00007fff75441960 r15: 0x000000010a0267e0
rip: 0x00007fff86517ce2 rfl: 0x0000000000000246 cr2: 0x0000000108cff000
Logical CPU: 0
Binary Images:
0x108c0c000 - 0x108c0cfff MIDIServer (??? - ???) <611CCAD7-F706-37A3-A957-4F74184B852E> /System/Library/Frameworks/CoreMIDI.framework/MIDIServer
0x108c12000 - 0x108c63ff7 com.apple.audio.midi.CoreMIDI (1.8 - 42) <CB0357AF-15B1-34AC-865A-6AC8F39F780E> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x108cf4000 - 0x108cf9fff com.apple.FWAUserLib (2.6.5 - 2.6.5fc3) <501D4255-2EF3-329F-A747-71BD91DF6DD3> /System/Library/Frameworks/FWAUserLib.framework/Versions/A/FWAUserLib
0x109f5c000 - 0x109f66fff com.apple.AppleMIDIFWDriver (265.4.1 - 265.4.3) <449CA07F-6A51-3EE4-8C61-034066B88771> /System/Library/Extensions/AppleMIDIFWDriver.plugin/Contents/MacOS/AppleMIDIFWDriver
0x109ff5000 - 0x109ff7ff7 com.apple.AppleMIDIIACDriver (1.8 - 42) <28B5E67B-94FC-3121-9CF9-C4F578E3F4C7> /System/Library/Extensions/AppleMIDIIACDriver.plugin/Contents/MacOS/AppleMIDIIACDriver
0x109ffc000 - 0x10a00eff7 com.apple.AppleMIDIRTPDriver (1.8 - 42) <87E21340-77B4-3214-84A2-D2E7E5F3CD99> /System/Library/Extensions/AppleMIDIRTPDriver.plugin/Contents/MacOS/AppleMIDIRTPDriver
0x10a015000 - 0x10a01dff7 com.apple.AppleMIDIUSBDriver (1.8 - 42) <9F2030E9-23A1-3652-94F8-029B14D54E97> /System/Library/Extensions/AppleMIDIUSBDriver.plugin/Contents/MacOS/AppleMIDIUSBDriver
0x10a023000 - 0x10a027fff +Fireface MIDI (3.09 - 3.09) <E0003F7C-270F-A8AF-F688-D11D93503213> /Library/Audio/MIDI Drivers/Fireface MIDI.plugin/Contents/MacOS/Fireface MIDI
0x7fff6880c000 - 0x7fff68840baf dyld (195.6 - ???) <C58DAD8A-4B00-3676-8637-93D6FDE73147> /usr/lib/dyld
0x7fff84834000 - 0x7fff84a08ff7 com.apple.CoreFoundation (6.7.2 - 635.21) <62A3402E-A4E7-391F-AD20-1EF20236CE1B> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff84a48000 - 0x7fff84a63fff libexpat.1.dylib (7.2.0 - compatibility 7.0.0) <DDB91E75-A2FA-331F-8069-999127AC6A9D> /usr/lib/libexpat.1.dylib
0x7fff84a64000 - 0x7fff84a68fff libdyld.dylib (195.6.0 - compatibility 1.0.0) <FFC59565-64BD-3B37-90A4-E2C3A422CFC1> /usr/lib/system/libdyld.dylib
0x7fff84c7c000 - 0x7fff84de3fff com.apple.CFNetwork (520.4.3 - 520.4.3) <31D7A595-375E-341A-8E97-21E73CC62E4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff852cb000 - 0x7fff85319fff libauto.dylib (??? - ???) <D8AC8458-DDD0-3939-8B96-B6CED81613EF> /usr/lib/libauto.dylib
0x7fff856e7000 - 0x7fff8575afff libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <6BDD43E4-A4B1-379E-9ED5-8C713653DFF2> /usr/lib/libstdc++.6.dylib
0x7fff8575b000 - 0x7fff85760ff7 libsystem_network.dylib (??? - ???) <DD7492F9-39FB-3E73-9028-3E1027D012B9> /usr/lib/system/libsystem_network.dylib
0x7fff85761000 - 0x7fff85767ff7 libunwind.dylib (30.0.0 - compatibility 1.0.0) <1E9C6C8C-CBE8-3F4B-A5B5-E03E3AB53231> /usr/lib/system/libunwind.dylib
0x7fff864b1000 - 0x7fff864b6fff libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <98ECD5F6-E85C-32A5-98CD-8911230CB66A> /usr/lib/system/libcompiler_rt.dylib
0x7fff86501000 - 0x7fff86521fff libsystem_kernel.dylib (1699.31.2 - compatibility 1.0.0) <185823F1-409E-3AFD-93A9-C214013C17C8> /usr/lib/system/libsystem_kernel.dylib
0x7fff86526000 - 0x7fff86568ff7 libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <A5B9778E-11C3-3F61-B740-1F2114E967FB> /usr/lib/system/libcommonCrypto.dylib
0x7fff865c3000 - 0x7fff865d5ff7 libbsm.0.dylib (??? - ???) <666E88F0-F8F3-3490-B688-2CF9418CB7E8> /usr/lib/libbsm.0.dylib
0x7fff865d6000 - 0x7fff866e2fff libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <557A7749-70EE-3ADF-BC3E-0A5E7DDCD8C1> /usr/lib/libcrypto.0.9.8.dylib
0x7fff866e3000 - 0x7fff867c7ed7 libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <76082BBC-446B-3355-AED5-0DBCEE600CB2> /usr/lib/libobjc.A.dylib
0x7fff867cc000 - 0x7fff86ae8fff com.apple.CoreServices.CarbonCore (960.24 - 960.24) <CDCB53C0-D212-3485-A594-DDE33AAC5AF0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff86ae9000 - 0x7fff86b59fff com.apple.datadetectorscore (3.0 - 179.4) <D14F635D-D403-3780-85C9-91EB0CA07F8E> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff86cba000 - 0x7fff86ceaff7 com.apple.DictionaryServices (1.2.1 - 158.2) <3107DEB8-A19E-3C51-8F2D-67CCE49FD401> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff86ddd000 - 0x7fff86ddefff libunc.dylib (24.0.0 - compatibility 1.0.0) <0482C762-746D-37EB-A8C9-E1048CF70462> /usr/lib/system/libunc.dylib
0x7fff86e82000 - 0x7fff8719bfff com.apple.Foundation (6.7.2 - 833.25) <F6584E06-7C8F-3422-AF84-3AA58EC67935> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff87a89000 - 0x7fff87ab4ff7 libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <E71220D3-8015-38EC-B97D-7FDB383C2BDC> /usr/lib/libxslt.1.dylib
0x7fff89177000 - 0x7fff89178ff7 libremovefile.dylib (21.1.0 - compatibility 1.0.0) <8901B7EE-6CA0-31F3-BBFE-BB71C90B1E49> /usr/lib/system/libremovefile.dylib
0x7fff8922e000 - 0x7fff8926dfff com.apple.AE (527.7 - 527.7) <9B3F7EC2-EDE2-3123-BAA5-C36A09BA038E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff8926f000 - 0x7fff8927aff7 libc++abi.dylib (14.0.0 - compatibility 1.0.0) <8FF3D766-D678-36F6-84AC-423C878E6D14> /usr/lib/libc++abi.dylib
0x7fff892d8000 - 0x7fff892e2ff7 liblaunch.dylib (392.38.0 - compatibility 1.0.0) <6ECB7F19-B384-32C1-8652-2463C1CF4815> /usr/lib/system/liblaunch.dylib
0x7fff8955e000 - 0x7fff895e1fef com.apple.Metadata (10.7.0 - 627.35) <6769AD6A-58D2-3D25-B289-15C65B82CF8D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff895e2000 - 0x7fff895e8fff com.apple.DiskArbitration (2.4.1 - 2.4.1) <22E77322-56E7-3730-9289-D8825A08408F> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff896cc000 - 0x7fff896dfff7 libCRFSuite.dylib (??? - ???) <322486D1-359C-3059-BF53-D4B038621E18> /usr/lib/libCRFSuite.dylib
0x7fff8970e000 - 0x7fff8970efff com.apple.CoreServices (53 - 53) <97E086D0-20B4-3BB4-BEE2-04EE5700D55B> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff8971b000 - 0x7fff89786ff7 com.apple.framework.IOKit (2.0 - ???) <BA8FC1EB-0360-394F-9D6C-1D58BB187466> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff89787000 - 0x7fff897d3ff7 com.apple.SystemConfiguration (1.11.3 - 1.11) <0A7F1982-B4EA-3424-A0C7-FE46C6224F03> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff898ff000 - 0x7fff89911ff7 libz.1.dylib (1.2.5 - compatibility 1.0.0) <30CBEF15-4978-3DED-8629-7109880A19D4> /usr/lib/libz.1.dylib
0x7fff8996d000 - 0x7fff8996ffff com.apple.TrustEvaluationAgent (2.0 - 1) <3087AE86-B57F-3D39-9885-C93DC6FD5163> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff8997c000 - 0x7fff89980fff libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <FF83AFF7-42B2-306E-90AF-D539C51A4542> /usr/lib/system/libmathCommon.A.dylib
0x7fff89981000 - 0x7fff8998fff7 libkxld.dylib (??? - ???) <9F65E9DF-2A92-3CE2-BA34-247D392DAB48> /usr/lib/system/libkxld.dylib
0x7fff899e9000 - 0x7fff899eafff libDiagnosticMessagesClient.dylib (??? - ???) <3DCF577B-F126-302B-BCE2-4DB9A95B8598> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff89d99000 - 0x7fff89da0fff libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <65602684-33B1-32DE-802B-050CE07659AC> /usr/lib/system/libcopyfile.dylib
0x7fff89f5a000 - 0x7fff89f69fff libxar-nossl.dylib (??? - ???) <518C0791-AB8D-3E8A-BB40-D4F312704FE2> /usr/lib/libxar-nossl.dylib
0x7fff8af43000 - 0x7fff8b020fef libsystem_c.dylib (763.13.0 - compatibility 1.0.0) <535C622E-2C14-3DD4-98D0-EA181DF8D582> /usr/lib/system/libsystem_c.dylib
0x7fff8b092000 - 0x7fff8b093fff libdnsinfo.dylib (395.11.0 - compatibility 1.0.0) <853BAAA5-270F-3FDC-B025-D448DB72E1C3> /usr/lib/system/libdnsinfo.dylib
0x7fff8b219000 - 0x7fff8b320fe7 libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <EE02BB01-64C9-304D-9719-A35F5CD6D04C> /usr/lib/libsqlite3.dylib
0x7fff8b321000 - 0x7fff8b326fff libcache.dylib (47.0.0 - compatibility 1.0.0) <3D114C8A-AD1F-3C78-9E8C-B8F3810740E5> /usr/lib/system/libcache.dylib
0x7fff8b353000 - 0x7fff8b358fff libpam.2.dylib (3.0.0 - compatibility 3.0.0) <D952F17B-200A-3A23-B9B2-7C1F7AC19189> /usr/lib/libpam.2.dylib
0x7fff8b395000 - 0x7fff8b3acfff com.apple.CFOpenDirectory (10.7 - 146) <BBB7C97E-7B46-3286-9128-32B5D16B5CBE> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff8b43a000 - 0x7fff8b448fff libdispatch.dylib (187.9.0 - compatibility 1.0.0) <1D5BE322-A9B9-3BCE-8FAC-076FB07CF54A> /usr/lib/system/libdispatch.dylib
0x7fff8c9fa000 - 0x7fff8ca16ff7 com.apple.GenerationalStorage (1.0 - 126.1) <509F52ED-E54B-3FEF-B3C2-759387B826E6> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff8caae000 - 0x7fff8caaefff libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <61EFED6A-A407-301E-B454-CD18314F0075> /usr/lib/system/libkeymgr.dylib
0x7fff8cb0a000 - 0x7fff8cb45fff libsystem_info.dylib (??? - ???) <35F90252-2AE1-32C5-8D34-782C614D9639> /usr/lib/system/libsystem_info.dylib
0x7fff8cb46000 - 0x7fff8cd48fff libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <38CD6ED3-C8E4-3CCD-89AC-9C3198803101> /usr/lib/libicucore.A.dylib
0x7fff8cdf5000 - 0x7fff8cdfdfff libsystem_dnssd.dylib (??? - ???) <8A0F6F23-53C1-34FD-B641-4C0771C71E2A> /usr/lib/system/libsystem_dnssd.dylib
0x7fff8ce3e000 - 0x7fff8ce3fff7 libsystem_sandbox.dylib (??? - ???) <96D38E74-F18F-3CCB-A20B-E8E3ADC4E166> /usr/lib/system/libsystem_sandbox.dylib
0x7fff8ce6c000 - 0x7fff8ce7afff com.apple.NetAuth (3.2 - 3.2) <B247BEAB-E3DA-3075-A2E5-BD3371AB0FA4> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff8ced6000 - 0x7fff8d1bfff7 com.apple.security (7.0 - 55148.1) <19F7B16B-B974-3274-886F-B8B2FA56032F> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff8d425000 - 0x7fff8d42eff7 libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <A4D651E3-D1C6-3934-AD49-7A104FD14596> /usr/lib/system/libsystem_notify.dylib
0x7fff8d623000 - 0x7fff8d62afff com.apple.NetFS (4.0 - 4.0) <30AAE235-3F64-38BC-B0C9-271C8979C1C9> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff8ebba000 - 0x7fff8ebbbfff liblangid.dylib (??? - ???) <CACBE3C3-2F7B-3EED-B50E-EDB73F473B77> /usr/lib/liblangid.dylib
0x7fff8efed000 - 0x7fff8f087ff7 com.apple.SearchKit (1.4.0 - 1.4.0) <C5585E08-76A0-34E0-B92C-22BA9D3E083C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff8f568000 - 0x7fff8f595fe7 libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <1984E3E7-8A90-338F-93F1-6EB44C212C9C> /usr/lib/libSystem.B.dylib
0x7fff8fbf6000 - 0x7fff8fcdafff com.apple.CoreServices.OSServices (478.46 - 478.46) <DAE95FD5-AA73-30E2-B563-EA2BDBD4D3CF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff901e3000 - 0x7fff901e9fff libmacho.dylib (800.0.0 - compatibility 1.0.0) <548BAEB6-8C4C-3B0F-AB0C-7E1C960BCAB5> /usr/lib/system/libmacho.dylib
0x7fff901eb000 - 0x7fff9028cff7 com.apple.LaunchServices (480.34 - 480.34) <67D5B865-B4B6-3522-8652-654A4E3F4B6D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff9072f000 - 0x7fff9073cff7 libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <DFAB8CA8-CC9D-3F58-8C12-CE120442AACD> /usr/lib/libbz2.1.0.dylib
0x7fff90abd000 - 0x7fff90b33fff libc++.1.dylib (28.1.0 - compatibility 1.0.0) <DA22E4D6-7F20-3BEA-9B89-2FBA735C2EE1> /usr/lib/libc++.1.dylib
0x7fff90c38000 - 0x7fff90d3afff libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <AFBB22B7-07AE-3F2E-B88C-70BEEBFB8A86> /usr/lib/libxml2.2.dylib
0x7fff90dc1000 - 0x7fff90dc2ff7 libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <8BCA214A-8992-34B2-A8B9-B74DEACA1869> /usr/lib/system/libsystem_blocks.dylib
0x7fff9183b000 - 0x7fff91858fff libxpc.dylib (77.19.0 - compatibility 1.0.0) <9F57891B-D7EF-3050-BEDD-21E7C6668248> /usr/lib/system/libxpc.dylib
0x7fff918ef000 - 0x7fff918f1fff libquarantine.dylib (36.6.0 - compatibility 1.0.0) <0EBF714B-4B69-3E1F-9A7D-6BBC2AACB310> /usr/lib/system/libquarantine.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 726
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=77.1M resident=44.4M(58%) swapped_out_or_unallocated=32.7M(42%)
Writable regions: Total=49.9M written=432K(1%) resident=764K(1%) swapped_out=0K(0%) unallocated=49.1M(99%)
REGION TYPE VIRTUAL
MALLOC 39.5M
MALLOC guard page 48K
STACK GUARD 56.0M
Stack 10.0M
VM_ALLOCATE 40K
__DATA 3108K
__LINKEDIT 49.2M
__TEXT 27.9M
__UNICODE 544K
mapped file 15.6M
shared memory 16K
TOTAL 202.0M
