Topic: Totalmix workplace upon startup
I recently upgraded my Fireface UC to UFX, using Windows 7.
Firmware and driver have been upgraded to the latest version.
When I used FF UC, my previous totalmix workplace setting is preserved everytime when I shut down and start up my Windows.
However for FF UFX, each time when I startup Windows, the totalmix workplace is reset to its default setting. So, I have to load my previous saved workplace everytime, which is very annoying.
How to solve?
Re: Totalmix workplace upon startup
Driver and firmware version?
TotalMix FX V0.983
Firmware V1.51
Thanks!
If TM FX can not write its current state into a file on shutdown then there must be a reason for that. You can try to analyze what is going on by checking the files (contents and date) in C:\Users\username\AppData\Local\TotalMixFX.
It shows that last.FirefaceUFX1.xml was last updated on 21/10/2011. And the rme.totalmix.default.xml and rme-totalmix.presents.xml were last updated on 13/3/2012. Then?
So no clue?
