Topic: HDSP 9632 / Windows 7 (64 bit) / HDMI problem
since I've installed a new monitor (SAMSUNG CA650), I keep haviong problem with my HDSP 9632 (PCI) soundcard.
First, hen I start windows seven, sometimes the driver of the soundcard can't be started.
Now I keep having crackle problem, using winamp, kmplayer, flstudio, etc...
I disabled the other devices : ATI High Definition Audio Device, Realtek High Definition Device, Son Intel(R) pour écrans.
But nothing works.
Everyhting was working fine before I used this HDMI monitor.
Any Idea how to solve this problem ?
Thank you.
Re: HDSP 9632 / Windows 7 (64 bit) / HDMI problem
I keep having the same problem on device manager "Ce périphérique ne peut pas démarrer. (Code 10)". "This device can't start".
Any help ? Please ?
If i try to update the driver from the list, choosing "hdsp.inf" file .
It says "The specified location does not contain a compatible software driver for your device. If the location contains a driver, make sure it is designed to work with the Windows x64 Edition operating system."
Remove the 9632 card and clean its golden PCI contacts with a rubber eraser.
I removed the card and it's working. Thank you MC.
