Topic: Babyface Problems
Hello
I have many problems with Babyface on my Macbook Pro.
I'm on 10.7.4
In the Plogue Bidule program, when launching my patch I have to error messages :
First one is :
Driver timed out on play!
And then :
Babyface (23380517)(out)
Portaudio error (Pa_StartStrem : -10000): Hosr error. Host Error(1852797029)
I need to restart to fix this.
After waking the mac from sleep, my DAW (Digital Performer) refuses to engage playing.
The console is full of messages like this :
15/08/12 16:22:16,000 kernel: IOAudioStream[0xffffff8013014200]::clipIfNecessary() - Error: attempting to clip to a position more than one buffer ahead of last clip position (349,924)->(35f,660).
15/08/12 16:22:16,000 kernel: IOAudioStream[0xffffff8013014200]::clipIfNecessary() - adjusting clipped position to (35e,924)
15/08/12 16:22:16,000 kernel: IOAudioStream[0xffffff8013014400]::clipIfNecessary() - Error: attempting to clip to a position more than one buffer ahead of last clip position (349,924)->(35f,660).
15/08/12 16:22:16,000 kernel: IOAudioStream[0xffffff8013014400]::clipIfNecessary() - adjusting clipped position to (35e,924)
15/08/12 16:22:16,000 kernel: IOAudioStream[0xffffff8013058c00]::clipIfNecessary() - Error: attempting to clip to a position more than one buffer ahead of last clip position (349,924)->(35f,660).
15/08/12 16:22:16,000 kernel: IOAudioStream[0xffffff8013058c00]::clipIfNecessary() - adjusting clipped position to (35e,924)
15/08/12 16:22:16,000 kernel: IOAudioStream[0xffffff8013014200]::clipIfNecessary() - Error: attempting to clip to a position more than one buffer ahead of last clip position (349,d24)->(35f,124).
15/08/12 16:22:16,000 kernel: IOAudioStream[0xffffff8013014200]::clipIfNecessary() - adjusting clipped position to (35e,d24)
15/08/12 16:22:16,000 kernel: IOAudioStream[0xffffff8013014400]::clipIfNecessary() - Error: attempting to clip to a position more than one buffer ahead of last clip position (349,d24)->(35f,124).
15/08/12 16:22:16,000 kernel: IOAudioStream[0xffffff8013014400]::clipIfNecessary() - adjusting clipped position to (35e,d24)
15/08/12 16:22:16,000 kernel: IOAudioStream[0xffffff8013058c00]::clipIfNecessary() - Error: attempting to clip to a position more than one buffer ahead of last clip position (349,d24)->(35f,124).
15/08/12 16:22:16,000 kernel: IOAudioStream[0xffffff8013058c00]::clipIfNecessary() - adjusting clipped position to (35e,d24)
I need to change the hardware setup on the DAW to buit-in audio and then re-choose te interface to fix this.
I use the latest driver (Fireface USB Driver v1.75) and firmware.
Thanks for your help
Yan
Re: Babyface Problems
I can add that all these problems tend to occur after a wake from sleep from the Macbook pro.
After a restart, it usually works fine. But the first error also happened after a restart.
Best
Yan
More info on problem #1
Plogue Bidule error messages :
First one is :
And then :
In console :
16/08/12 08:24:39,579 [0x0-0xa60a6].com.plogue.bidule: PaOSX_OpenCommonDevice: AudioDeviceAddPropertyListener failed.
16/08/12 08:24:42,959 [0x0-0xa60a6].com.plogue.bidule: PaOSX_OpenCommonDevice: timed out waiting for device format to settle.
16/08/12 08:24:42,959 [0x0-0xa60a6].com.plogue.bidule: PaHost_StartEngine: AudioDeviceAddIOProc primary failed: error = 0x6E6F7065 = 'kAudioHardwareIllegalOperationError'
Best
Yan
Unplugging the Babyface usb cable after this error does not quit the "Fireface USB Settings" as it normally does.
I have to restart the mac.
Yan
5
We are examining this effect right now. Stay tuned please.
On pluging it, why would the Babyface won't launch the USB settings and TotalMic apps?
Yan
7
Please try the new drivers from today, that sleep problem has been fixed.
Thank you very much !
Best
Yan
