Topic: General Midi Control / Note messages
hi,
we are controlling the Fireface Mixer with stamdard midi controllers.
for the controllers no problems.
but for the note messages this did not work when DISABLING the "Mackie Control Options / Enable Protocol Support" button.
As said, we have no mackie control, just normal midi messages.
thanks for assistance
cheers
Intel DX58SO2 / Core i7-960 / Kingston HyperX 1600 24 GB / Fireface800 / Windows 7 Pro 64 bit
Re: General Midi Control / Note messages
These are part of the Mackie protocol.
3 (edited by mididoc 2012-08-16 19:18:42)
thanks,
good to know.
<bg>
is there a midi message for bringing the mixer window into focus, say open it?
Sorry, no.
thanks anyway for the fast info.
can be done with a key command and the windows link.
thanks
good stuff
<bg>
6 (edited by ndeflache 2012-09-14 15:14:04)
the answer is fast, BUT:
In chapter 30.5 of the manual, is explained how to use Notes and Control Change, WHEN NOT USING MACKIE CONTROL.
Control Change do indeed control faders, but it is not mentionned at all that notes will work only in Mackie Control Mode.
It is disappointing that RME doesn't support these simple "hardware" MIDI messages:
- mute, solo, pan for each channel, the same way faders are controlled
- control room commands mentionned in chapter 30.5
Thank you.
Nicolas
