Topic: Windows Soundmix output as input for Asio (nuendo)
Is it possible to digitally (internally) re-route the windows output device (if i select the RME one) as an input for Nuendo? Using my Fireface 400.
Cheers
Anton
Re: Windows Soundmix output as input for Asio (nuendo)
You can route back hardware outputs of the Fireface to hardware inputs via Totalmix. Say your Windows sound outputs were outputs 3+4, then you could route those back to inputs 3+4 and use those inputs Nuendo.
found it. page 70 of the manual: recordign a subgroup (loopback)
Ok the manual says this:
To activate this function, click on the red label in the third row while holding down the Ctrl-key.
The label's colour changes to red. In case the channel has already been part of a group, the
colour will change from yellow to orange, signalling that the group functionality is still active for
this channel.
But for the live of me I cannot find a red thing anywhere.
5
Thanks for pointing out that error, I will fix it. The correct description is found in chapter 30.3:
The grey area shows the channel name. Selecting one or more channels is done by clicking on the grey label which turns orange then. A click in the third row with pressed Ctrl-key activates internal loopback mode, the label turns red.
