Topic: RME hdsp aes32 + Lynx Aurora16 routing failure!
i have a big problem!
for any reason, the routing in my totalmix is linked to something like stereo channels!
channel1 from the lynx is on Input 1+2 in totalmix (signal is only on input1)
channel2 from the lynx is on channel 3+4(signal meters are only on channel3)
channel3 from the lynx is on channel 5+6(signal meters are only on channel5)
and so on!
does anybody know whats wrong here???
its everything connected like always,...i just moved my setup to a new location.
i already checked the D-sub connectors, the settings on the Lynx, the matrix,...
really dont know whats wrong here!
cheers
Re: RME hdsp aes32 + Lynx Aurora16 routing failure!
Unclear description. You either have this:
Keyboard hotkey L. Toggles link mode.
Or this:
SMUX mode (96 kHz) active but not on all devices.
Or this:
Wrong setting for single/double wire mode in the AES Settings dialog.
what and where is SMUX mode? where can i change that?
and why shouzld it be on now when i didnt change anything?
Single/Double wire mode can be controlled on both your Lynx and the card's Settings dialog. Screenshots of Settings and TM would be helpful to see what is going wrong.
you should get a message from the support hotline, spoke to them a few minutes ago but no success.
that really sucks big time!
i should record since yesterday but now everything stands still.
i tried to reboot with 96khz just to see what happens.
the only thing that happend was that i can see the input signal now on both channels.
1+2, 3+4, 5+6 as a stereo pair.
7
To check what is going on: can you connect the AES input with the AES output, set the Clock Mode to Master, then play a signal from some software? It should register in TM exactly as intended. If so the settings in the Lynx must be wrong. I am not familiar with that unit, but shouldn't the Sync Source be set to 'Internal' instead of LSlot? That sounds like slave mode to me.
