Topic: UFX buffer size problem
I recently discovered that when using my UFX connected with firewire, I am not able to use 48 samples at 48KHz. For instance using windows media player to playback music, the errors counter in fireface settings increase fast and no sound is produced. Interestingly it works fine on 48 samples on 44.1KHz, and 96 samples on 192KHz. Essentially, all the other combinations of buffer size and sample rate work fine. Is this something that has been seen before or only weirdness in my system?
Torstein
