Topic: Problem with Multiface I and HSDP PCI card rev 1.8 on Win7 x64
I have computer with Windows 7 64 bit, and for a long time I was using Multiface I interface with PCI HSDP card rev 1.4. It was working very good except of occasional problem with boot initialisation (as described here: http://www.rme-audio.de/old/english/faq/hdsp_pci.htm).
To avoid initialisation problems i decided to upgrade PCI card and have bought used HSDP PCI card rev 1.8 on ebay. I have installed newest driver 3.29 (tried also 3.085 from 08/05/2010) and updated succesfully flash to revision 55.
Unfortunatelly after installation soundcard is not working.
When I run Hammerfall DSP Settings first tab shows RPM(1) or Digiface(1) (not multiface) and I/O Box state change periodically from connected to disconnected.
HDSP Mixer window also act oddly - windows size and number of input/output channels is changing all the time.
Error led on multiface is not lit.
I have try to connect external power supply to multiface - nothing changed.
Do you have any sugestion if it is possible to make my new configuration working ?
Is there any place where I can download older drivers version ?
I'm sure that Multiface interface is operational.
The previous owner states in the item description, that card is fully operational.
I would be grateful for any suggestions/help.
PS. when I switched back to the older rev1.4 card everything works fine. I'm worried that the second card may be broken?
Przemek
