Topic: Wrong Input Level Fireface 800
I have imported into Sonar a wav file from 44.1k and 24bit with a sine wave of 1000 Hz @ -1.0,
the playback and the output in Fireface mixer are correct, i have connected analog input 1 and
output 1 in loop-back with a balanced cable, but the Fireface mixer measure to input 1 -1.53,
why not -1.0 ??
[img align=L]http://www.bonisaudio.com/level.jpg[/img]
www.bonisaudio.com
Re: Wrong Input Level Fireface 800
Because both input and output stages have a small intentional offset to prevent overload. If in your example both levels would be set to match 100%, and the usual deviation during manufacturing causes a positive offset of only 0.1 dB, you would get overloads already. So better loose a little bit and stay on the safe side.
offset
The 'input DC offset errors' , you're writing about this?
I know that the input offset voltage being typically about 100 mV and the distortion is very low... even into a 600 Ohm.
Sorry, but i have understand your answer in correct way ?
www.bonisaudio.com
No, this is not about DC. And I don't know of any typical 100 mV DC anywhere.
Please, can you explain to me what kind of offset you're talking about ?
Thank you
Bonis
www.bonisaudio.com
6
Output level should be +13 dBu at 0 dBFS, but reaches only 12.8 dBu. Input should reach 0 dBFS at +13 dBu, but needs +13.2 dBu.
This is the result of the levels without optimizing anything in re-recording, ok, thank you MC.
[img align=L]http://www.bonisaudio.com/Rme_ff800_check_level_and_loopback.jpg[/img]
www.bonisaudio.com
I am curious if anyone can confirm that the UFX behaves the same?
9
All our units. This is by design, means intentionally.
The RME units are music recording tools, not scientific measuring instruments!  They've been designed with a little extra protection against overload - when you THINK you're hitting 0dB you're actually a little lower.  Less chance of overload.  Don't worry about it.
11 (edited by bonis 2012-09-24 02:34:08)
Laurence, i have not complained, but i think the users who buys this card requires hight precision, otherwise i think to buy a Sounblaster, i have only asked this for know if some of my outboards was defective.
MC
I thought at first that you were talking about DC OFFSET, after i have understood what you meant.
PS
Here in my part (country) the DC OFFSET has a positive or negative domain range and this values are generally measured in mV.
www.bonisaudio.com
I see your point.  But it's a musical tool, not a scientific measuring device.  There are different kinds of "precision".  If a slightly optimistic metering strategy decreases the chance of overload, and therefore huge loss of musical "precision", it can be considered a good idea!
I hope this imprecision-by-design is documented thogh?
13
You ever tried to listen to a 0.2 dB level difference? You ever checked your other equipments accuracy (be prepared for some surprises)? The 'precision' is there, even with levels. We are talking about things where other manufacturers would not give any information at all...
Sometimes I miss a "Like" button on this forum... cool
15 (edited by bonis 2012-09-24 20:48:42)
I REPEAT DO NOT HAVE COMPLAINED ABOUT HIS ACCURACY,
we all know the analogic limits in terms of perfect precision, now that i know...compensating.... smile
MC
When you mix 12 tracks also use your eyes @ ears ?
www.bonisaudio.com
Please can you tell me the dBu or dBV value of this -8.7 dBfs ???
[img align=L]http://www.bonisaudio.com/8_7_dbfs.jpg[/img]
www.bonisaudio.com
17
+13 dBu - 8.7 dB = +4.3 dBu
www.bonisaudio.com
19 (edited by bonis 2012-10-09 22:20:37)
Sorry but i'm a little confused with your +13 dBu at 0 dBFS.....
0dBFS is the level that the converters will clip ??
In a digital audio system the nominal line level is +4dB and full scale is often +22dB (18
dB of headroom) ??
0dBFS in this case is +13dB.
Consumer audio is usually specified as -10dBV for line level which is roughly 12 dB less ??
www.bonisaudio.com
20
Chapter 25.1 in the manual.
Chapter 26.1 in the manual. (Analog Outputs)
In the Reference talk about Hi Gain, but under (in the description) talk about Lo Gain.
Thank you MC
Ps
Great work @ Musikmesse 2012
www.bonisaudio.com
22
You use an outdated one. The latest one can be downloaded from our website.
MC i have the latest one, thanks anyway. :-)
www.bonisaudio.com
24
No you haven't. But yes, you couldn't. Because it is not yet on our website :-)
The FF 800 manuals have been completely updated to the latest drivers, I will upload them in about 2 weeks.
25 (edited by bonis 2012-10-12 18:29:54)
R O T F L
www.bonisaudio.com
26 (edited by bonis 2012-11-25 01:43:42)
One last question on this topic, yikes
attacking a very normal multimeter (value 22 €) with a sine (1kHz) @ -13 dBFS (0 dBu) what value i have to read from the display by connecting the leads between TIP and SLEEVE (about/approximate) if my FF800 work right ? (...without any load...)
[img align=L]http://www.xstreme.it/FF80MULTIM.jpg[/img]
www.bonisaudio.com
27
Invalid usage. You have to connect ring to ground. Or measure between ring and tip.
28 (edited by bonis 2012-11-25 12:05:17)
ok, thanks, in this case what value i have to read from the display of multimeter ? (with 1 kHz sine @ -13 dBfs) ...(ABOUT)... :-)
(i have updated the drawing)
www.bonisaudio.com
