Topic: TotalMix Bug report: MIDI, group and Playback channel ADAT9 to 16
Within a group, faders on Playback channel ADAT9 to 16 have different curve when they are controlled by MIDI.
- setup MIDI control of ADAT15 playback fader with Ch6, CC114
- activate Trim Gain thru Ch13, CC102
- in the matrix, connect ADAT15/16 to AN 7/8 and to ADAT 15/16
- connect ADAT13/14 to ADAT13/14 out
- in mixer, group the 3 corresponding faders with group 3
- move your slider and look at the matrix: connection ADAT15/16 to ADAT15/16 has a different curve than the others (twice more dB).
If you do the same with ADAT 1/2, no problem.
Nicolas
Re: TotalMix Bug report: MIDI, group and Playback channel ADAT9 to 16
The combination of Trim and grouped faders has been fixed in the latest TM FX:
http://www.rme-audio.de/forum/viewtopic … 193#p79193
Note that this has nothing to do with MIDI. The special treatment for this case already implemented did not work as expected in the second row.
Thank you
