Topic: Fireface ucx or adi2
Hello
I'd like to upgrade quality in my little home studio
I use UA610 solo preamp
Saffire pro 14 as interface
Imac
Focal solo6 be as monitors
beyerdynamic  dt770 pro headphones
Logic sequencer
My intent is step up ad/da conversion quality and two are ways i see
Change my Pro14 interface with one Rme ucx,uc or ufx
Add one Adi2 between preamp ua610 solo and Pro14 interface by spdif in (44.1 / 96 khz)
What is better choice in your opinion
I think a/d d/a quality is better in adi2 compared with ucx,uc and ufx converters
but i don't know if saffire 96 khz spdif in could be apt to make the most of Adi2 capability.
Also could be a better option to sacrifice a little a/d definition and get more I/O possibilities.
Fascinating dsp and effects too
Let me know your point of view
Thanks Ciao
Re: Fireface ucx or adi2
loyuit wrote:
Hello
Imac
Logic sequencer
Thanks Ciao
UFX all the way!! :-)
You not only get a converter upgrade, you also get RME drivers and software.
The drivers and stability alone are worth it in mu opinion.
Isaac P
Thank you Isaac
And there are many qualitative differences between ufx and ucx ?
I 'don't need a lot of I/O options, 18 are more than enough
4 (edited by isaac 2012-09-20 10:10:18)
loyuit wrote:
Thank you Isaac
They use different converter chips I believe. As the UCX is newer it should have better specs. Can't tell you 100%. Check the RME website for that.
I think that everything the UCX brings is more than worth choosing it over the ADI-2. The only reason I think for you to get the UFX would be DUrec and the extra inputs. Or if you wanted to use 96K over ADAT.
If I was upgrading my multifaces, the UCX would be my first stop!!!
Isaac P
Ok Isaac Thanks
In rme website it shows only different channels and possibilities between interfaces,not type and hardware quality
Anyway i think to get one ucx
Converters and Pre i presume they're similar in ucx and ufx
Real gap i believe is in number of channels,but ucx 18 I/O are a sufficient quantity for me
loyuit wrote:
Ok Isaac Thanks
I think you need to download the manuals to get the specs sorry!
Isaac P
loyuit wrote:
Ok Isaac Thanks
Be sure you understand with the UCX you only get 10 input channels unless you already have an analog-to-adat converter. If you don't already have (or are willing to purchase) an additional converter the ADAT inputs are useless.
