Topic: Fireface USB Settings quit unexpectedly
When I wake my Mac after sleep (usually a couple of hours, not minutes), the Fireface USB Settings has crashed.
The interface / driver itself, however, continues to work flawlessly. And I have to to say that RME really do live up to the notion of the most stabile drivers in the industry.
It is only the settings apps that crashes after/while in sleep, and it is not something that affects performance it is just a bit annoying to have it appear after sleep.
I'm running the interface via the built-in USB hub in my Cinema Display - could this be the issue? Also I'm running the latest drivers, and also the latest version of Mountain Lion.
My Mac is a Retina Display MacBook Pro.
Here is the error:
Process:         Fireface USB Settings [965]
Path:            /Applications/Fireface USB Settings.app/Contents/MacOS/Fireface USB Settings
Identifier:      de.rme-audio.Fireface_USB_Settings
Version:         1.76
Code Type:       X86 (Native)
Parent Process:  launchd [282]
User ID:         501
Date/Time:       2012-09-24 20:55:43.686 +0200
OS Version:      Mac OS X 10.8.2 (12C54)
Report Version:  10
Sleep/Wake UUID: 615D7B17-FED5-4C22-AF73-1FE1C186866E
Interval Since Last Report:          154317 sec
Crashes Since Last Report:           9
Per-App Crashes Since Last Report:   5
Anonymous UUID:                      5CF2CC90-D905-8A1B-E8C0-6B7DC21FE227
Crashed Thread:  0  Dispatch queue: com.apple.main-thread
Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000040000020
VM Regions Near 0x40000020:
    mapped file            0000000008ffc000-0000000009468000 [ 4528K] r--/rwx SM=COW  /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/Resources/ArtFile.bin
    __TEXT                 000000008fe38000-000000008fe6b000 [  204K] r-x/rwx SM=COW  /usr/lib/dyld
Application Specific Information:
objc_msgSend() selector name: _getValue:forType:
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   libobjc.A.dylib                   0x98a7da87 objc_msgSend + 23
1   com.apple.CoreFoundation          0x93f9c7a2 CFNumberGetValue + 130
2   de.rme-audio.Fireface_USB_Settings    0x000030da GetValue(__CFDictionary*, char const*) + 90
3   de.rme-audio.Fireface_USB_Settings    0x00003241 CHardware::LoadSettings(int) + 133
4   de.rme-audio.Fireface_USB_Settings    0x00004368 CHardware::OpenDriver() + 126
5   de.rme-audio.Fireface_USB_Settings    0x00004f61 -[Controller resetFirefaces] + 43
6   libobjc.A.dylib                   0x98a965d3 -[NSObject performSelector:withObject:] + 70
7   com.apple.Foundation              0x90cb40c0 __NSThreadPerformPerform + 395
8   com.apple.CoreFoundation          0x93f9c66f __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 15
9   com.apple.CoreFoundation          0x93f9c099 __CFRunLoopDoSources0 + 233
10  com.apple.CoreFoundation          0x93fc1e46 __CFRunLoopRun + 934
11  com.apple.CoreFoundation          0x93fc163a CFRunLoopRunSpecific + 378
12  com.apple.CoreFoundation          0x93fc14ab CFRunLoopRunInMode + 123
13  com.apple.HIToolbox               0x982b815a RunCurrentEventLoopInMode + 242
14  com.apple.HIToolbox               0x982b7ec9 ReceiveNextEventCommon + 374
15  com.apple.HIToolbox               0x982b7d44 BlockUntilNextEventMatchingListInMode + 88
16  com.apple.AppKit                  0x9990ca3a _DPSNextEvent + 724
17  com.apple.AppKit                  0x9990c26c -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 119
18  com.apple.AppKit                  0x999026cc -[NSApplication run] + 855
19  com.apple.AppKit                  0x998a56f6 NSApplicationMain + 1053
20  de.rme-audio.Fireface_USB_Settings    0x00002b4d start + 53
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0   libsystem_kernel.dylib            0x933b59ae kevent + 10
1   libdispatch.dylib                 0x91ddcc71 _dispatch_mgr_invoke + 993
2   libdispatch.dylib                 0x91ddc7a9 _dispatch_mgr_thread + 53
Thread 2:
0   libsystem_kernel.dylib            0x933b50ee __workq_kernreturn + 10
1   libsystem_c.dylib                 0x9090404c _pthread_workq_return + 45
2   libsystem_c.dylib                 0x90903e19 _pthread_wqthread + 448
3   libsystem_c.dylib                 0x908ebcca start_wqthread + 30
Thread 3:
Thread 0 crashed with X86 Thread State (32-bit):
  eax: 0x0016d3d0  ebx: 0x93f9c731  ecx: 0x90ea6f45  edx: 0x40000000
  edi: 0x93f9c731  esi: 0x90ea6f45  ebp: 0xbfffe3e8  esp: 0xbfffe0d8
   ss: 0x00000023  efl: 0x00010202  eip: 0x98a7da87   cs: 0x0000001b
   ds: 0x00000023   es: 0x00000023   fs: 0x00000000   gs: 0x0000000f
  cr2: 0x40000020
Logical CPU: 0
Binary Images:
    0x1000 -     0x6ffb +de.rme-audio.Fireface_USB_Settings (1.76) <9CE9270C-2E38-F81A-19FF-F531110EE2AB> /Applications/Fireface USB Settings.app/Contents/MacOS/Fireface USB Settings
   0x7e000 -    0x8bff3  com.apple.Librarian (1.1 - 1) <88A55A5E-40FF-3234-8394-2317120B79AB> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
  0x724000 -   0x729fff  com.apple.audio.AppleHDAHALPlugIn (2.3.1 - 2.3.1f2) <58BDA15D-2B2D-3E77-BC8C-D14AB1E4AC4E> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
  0x72e000 -   0x738ffb  com.apple.iokit.IOUSBLib (5.2.5 - 5.2.5) <E0E03D63-CF3D-3C34-8FE0-5E92CF648DB4> /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
0x8fe38000 - 0x8fe6ae57  dyld (210.2.3) <23516BE4-29BE-350C-91C9-F36E7999F0F1> /usr/lib/dyld
0x9000a000 - 0x9008fff7  com.apple.SearchKit (1.4.0 - 1.4.0) <454E950F-291C-3E95-8F35-05CA0AD6B327> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x90090000 - 0x90448ffa  libLAPACK.dylib (1073.4) <9A6E5EAD-F2F2-3D5C-B655-2B536DB477F2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x90449000 - 0x90660fff  com.apple.CoreData (106.1 - 407.7) <17FD06D6-AD7C-345A-8FA4-1F0FBFF4DAE1> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x9066b000 - 0x90678fff  libGL.dylib (8.6.1) <C7A3917A-C444-33CC-8599-BB9CD8C12BC4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x90679000 - 0x90679ffd  com.apple.audio.units.AudioUnit (1.8 - 1.8) <4C13DEA2-1EB0-3D06-901A-DB93184C06F0> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9067a000 - 0x9067cffb  libRadiance.dylib (845) <3F87840F-217D-3074-A29D-919BAAED2F4A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x9067d000 - 0x9067dfff  com.apple.Accelerate (1.8 - Accelerate 1.8) <4EC0548E-3A3F-310D-A366-47B51D5B6398> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x906ad000 - 0x906d1fff  libJPEG.dylib (845) <547FA9A5-0BBB-3E39-BACA-F3E2DAE57DB0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x906d2000 - 0x90729ff3  com.apple.HIServices (1.20 - 417) <561A770B-8523-3D09-A763-11F872779A4C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x9072a000 - 0x9073cfff  libbsm.0.dylib (32) <DADD385E-FE53-3458-94FB-E316A6345108> /usr/lib/libbsm.0.dylib
0x9073d000 - 0x9073effd  com.apple.TrustEvaluationAgent (2.0 - 23) <E42347C0-2D3C-36A4-9200-757FFA61B388> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x90744000 - 0x9074cfff  libcopyfile.dylib (89) <4963541B-0254-371B-B29A-B6806888949B> /usr/lib/system/libcopyfile.dylib
0x9074d000 - 0x908c5ff5  com.apple.QuartzCore (1.8 - 304.0) <0B0EC55A-9084-3E28-9A84-1813CE3FAA9B> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x908c6000 - 0x908c7ffd  libunc.dylib (25) <58599CBF-E262-3CEA-AFE1-35560E0177DC> /usr/lib/system/libunc.dylib
0x908c8000 - 0x908eafff  libc++abi.dylib (24.4) <06479DA4-BC23-34B6-BAFC-A885814261D0> /usr/lib/libc++abi.dylib
0x908eb000 - 0x909a8feb  libsystem_c.dylib (825.25) <B1F6916A-F558-38B5-A18C-D9733625FDC9> /usr/lib/system/libsystem_c.dylib
0x909a9000 - 0x909b9ff2  com.apple.LangAnalysis (1.7.0 - 1.7.0) <875363E7-6D02-3229-A9DD-E5A5568A7D61> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x909ba000 - 0x909d7ff7  libresolv.9.dylib (51) <B9742A2A-DF15-3F6E-8FCE-778A58214B3A> /usr/lib/libresolv.9.dylib
0x909d8000 - 0x90a1dff5  com.apple.opencl (2.1.20 - 2.1.20) <41C4AE6E-67B6-33E2-A9B6-BF6F01580B16> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x90a1e000 - 0x90a3effd  com.apple.ChunkingLibrary (2.0 - 133.2) <FE5F0F1E-B15D-3F76-8655-DC2FE19BF56E> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x90a3f000 - 0x90a40fff  libremovefile.dylib (23.1) <98622D14-DAAB-3AD8-A5D9-C322BF572A98> /usr/lib/system/libremovefile.dylib
0x90acb000 - 0x90b31fff  com.apple.print.framework.PrintCore (8.1 - 387.1) <F8CF762B-B707-3021-958F-BB8D33DB3576> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x90b5a000 - 0x90b9cffb  com.apple.RemoteViewServices (2.0 - 80.5) <60E04F2F-AFD8-3B1F-BF07-8A3A7EABB8E9> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x90ba9000 - 0x90c18ffb  com.apple.Heimdal (3.0 - 2.0) <1ABF438B-30E6-3165-968C-E2EA1A9DF1FD> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x90c19000 - 0x90f36ff3  com.apple.Foundation (6.8 - 945.11) <03B242AC-519C-3683-AA52-E73536B3D55F> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x90f37000 - 0x90f3affd  libCoreVMClient.dylib (24.4) <C54E8FD0-61EC-3DC8-8631-54288AC66AC8> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x90f97000 - 0x910efffb  com.apple.audio.toolbox.AudioToolbox (1.8 - 1.8) <9205DFC2-8DAE-354E-AD87-46E229B5F2F1> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x915e1000 - 0x915fefff  libxpc.dylib (140.41) <1BFE3149-C242-3A77-9729-B00DEDC8CCF2> /usr/lib/system/libxpc.dylib
0x915ff000 - 0x91609fff  com.apple.speech.recognition.framework (4.1.5 - 4.1.5) <B855E8B4-2EE3-3BFF-8547-98A0F084F9AF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x9160a000 - 0x9160afff  libsystem_blocks.dylib (59) <3A743C5D-CFA5-37D8-80A8-B6795A9DB04F> /usr/lib/system/libsystem_blocks.dylib
0x9160f000 - 0x91668fff  com.apple.AE (645.3 - 645.3) <6745659F-006D-3F25-94D6-DF944E9A01FD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x91669000 - 0x91669fff  com.apple.Accelerate.vecLib (3.8 - vecLib 3.8) <908B8D40-3FB5-3047-B482-3DF95025ECFC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x9166a000 - 0x91693ff7  libRIP.A.dylib (324.6) <7976E6A2-A489-33F5-A727-7634DDE3B761> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x91694000 - 0x916b0ff7  libPng.dylib (845) <14C43094-C670-3575-BF9B-3A967E05EAC0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x916b1000 - 0x917ecff7  libBLAS.dylib (1073.4) <FF74A147-05E1-37C4-BC10-7DEB57FE5326> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x917ed000 - 0x91823ffb  com.apple.DebugSymbols (98 - 98) <9A9ADA0A-E487-3C8F-9998-286EE04C235A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x91824000 - 0x9185ffe7  libGLImage.dylib (8.6.1) <A3442557-18D5-332E-8859-423D5A20EBBE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x91860000 - 0x91860fff  libkeymgr.dylib (25) <D5E93F7F-9315-3AD6-92C7-941F7B54C490> /usr/lib/system/libkeymgr.dylib
0x918b6000 - 0x918baff7  libmacho.dylib (829) <5280A013-4F74-3F74-BE0C-7F612C49F1DC> /usr/lib/system/libmacho.dylib
0x91917000 - 0x91944ffe  libsystem_m.dylib (3022.6) <9975D9C3-3B71-38E3-AA21-C5C5F9D9C431> /usr/lib/system/libsystem_m.dylib
0x91979000 - 0x919acff3  com.apple.GSS (3.0 - 2.0) <B1D719C1-B000-3BE3-B747-329D608585DD> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x919ad000 - 0x91a3fffb  libvMisc.dylib (380.6) <6DA3A03F-20BE-300D-A664-B50A7B4E4B1A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x91a40000 - 0x91a41fff  libquarantine.dylib (52) <D526310F-DC77-37EA-8F5F-83928EFA3262> /usr/lib/system/libquarantine.dylib
0x91a93000 - 0x91bafff7  com.apple.desktopservices (1.7.2 - 1.7.2) <8E74D101-8398-34F1-A463-B4950680A597> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x91bb0000 - 0x91bb0fff  com.apple.Cocoa (6.7 - 19) <354094F0-F36B-36F9-BF5F-FD60590FBEB9> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x91c09000 - 0x91d16ff3  com.apple.ImageIO.framework (3.2.0 - 845) <BF959BCB-C30A-3680-B7C2-91B327B2B63B> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91d17000 - 0x91d23ffa  com.apple.CrashReporterSupport (10.8.2 - 414.3) <15321A03-11A6-39BE-B6F5-422F382B34AC> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x91d24000 - 0x91d43ff3  com.apple.Ubiquity (1.2 - 243.10) <D2C9F356-1681-31D2-B292-5227E2DDEB0B> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x91d44000 - 0x91d4effe  com.apple.bsd.ServiceManagement (2.0 - 2.0) <9732BA61-D6F6-3644-82DA-FF0D6FEEFC69> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x91dd8000 - 0x91deaff7  libdispatch.dylib (228.23) <86EF7D45-2D97-3465-A449-95038AE5DABA> /usr/lib/system/libdispatch.dylib
0x91e69000 - 0x91e71fff  com.apple.CommerceCore (1.0 - 26) <AF0D1990-8CBF-3AB4-99DF-8B7AE14FB0D5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x91e72000 - 0x91e7bffd  com.apple.audio.SoundManager (4.0 - 4.0) <ABC5FE40-B222-36EB-9905-5C8C4BFD8C87> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x91e7c000 - 0x91e7dfff  libdnsinfo.dylib (453.18) <41C7B8E2-2A81-31DE-BD8B-F0C29E169D4F> /usr/lib/system/libdnsinfo.dylib
0x91e7e000 - 0x91e81ff9  libCGXType.A.dylib (324.6) <3004616B-51F6-3B9D-8B85-DCCA3DF9BC10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x91ed0000 - 0x91ed7fff  liblaunch.dylib (442.26.2) <310C99F8-0811-314D-9BB9-D0ED6DFA024B> /usr/lib/system/liblaunch.dylib
0x92175000 - 0x9218cfff  com.apple.GenerationalStorage (1.1 - 132.2) <93694E0D-35D3-3633-976E-F354CBD92F54> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x9218d000 - 0x9218ffff  libCVMSPluginSupport.dylib (8.6.1) <8A174BD9-992E-351D-8F9A-DF6991723ABE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x921fb000 - 0x92211fff  com.apple.CFOpenDirectory (10.8 - 151.10) <56C3F276-BD1F-3031-8CF9-8F4F481A534E> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x92212000 - 0x9226cfff  com.apple.Symbolication (1.3 - 93) <684ECF0D-D416-3DF8-8B5B-3902953853A8> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x9238c000 - 0x9242cff7  com.apple.QD (3.42 - 285) <1B8307C6-AFA8-312E-BA5B-679070EF2CA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x9245b000 - 0x924a9ffb  libFontRegistry.dylib (100) <3B8350C2-4D8F-38C4-A22E-2F855D7E83D1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x924aa000 - 0x924b8fff  libxar.1.dylib (105) <343E4A3B-1D04-34A3-94C2-8C7C9A8F736B> /usr/lib/libxar.1.dylib
0x924c4000 - 0x924ddfff  com.apple.Kerberos (2.0 - 1) <9BDE8F4D-DBC3-34D1-852C-898D3655A611> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x92524000 - 0x9252efff  libCSync.A.dylib (324.6) <D2E8AC70-C6D1-3C40-8A82-E50422EDCFBF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x9252f000 - 0x92553fff  com.apple.PerformanceAnalysis (1.16 - 16) <18DE0F9F-1264-394D-AC56-6B2A1771DFBE> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x92636000 - 0x92682fff  libcorecrypto.dylib (106.2) <20EBADBA-D6D6-36F0-AE80-168E9AF13DB6> /usr/lib/system/libcorecrypto.dylib
0x926b4000 - 0x926c7ff9  com.apple.MultitouchSupport.framework (235.28 - 235.28) <5C8CFA21-D4FC-32E8-B199-0F7155E6ED9A> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x926c8000 - 0x926cbffc  libpam.2.dylib (20) <FCF74195-A99E-3B07-8E49-688D4A6F1E18> /usr/lib/libpam.2.dylib
0x926cc000 - 0x92748ff3  com.apple.Metadata (10.7.0 - 707.3) <6B6A6216-23D0-34CE-8099-BEE9BA42501E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9279c000 - 0x9279dfff  liblangid.dylib (116) <E13CC8C5-5034-320A-A210-41A2BDE4F846> /usr/lib/liblangid.dylib
0x92a21000 - 0x92a2dffe  libkxld.dylib (2050.18.24) <48A75AF6-9D5A-3552-948E-30A1682D3664> /usr/lib/system/libkxld.dylib
0x92d1a000 - 0x92d1afff  com.apple.vecLib (3.8 - vecLib 3.8) <83160DD1-5614-3E34-80EB-97041016EF1F> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x92d1b000 - 0x92d90ff7  com.apple.ApplicationServices.ATS (332 - 341.1) <95206704-F9C9-33C4-AF25-FE9890E160B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x92d91000 - 0x92e65fff  com.apple.backup.framework (1.4.1 - 1.4.1) <55F2A679-9B21-3F43-A580-4C2ECF6A5FC5> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x92e66000 - 0x932a8fff  com.apple.CoreGraphics (1.600.0 - 324.6) <66556166-F9A7-3EEC-A562-46061C7A79E4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x932a9000 - 0x93341fff  com.apple.CoreServices.OSServices (557.4 - 557.4) <C724AB29-A596-3E1E-9FF1-A4E509AD843A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x93342000 - 0x9339ffff  com.apple.audio.CoreAudio (4.1.0 - 4.1.0) <9549B81F-4425-34EE-802B-F462068DC0C5> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x933a0000 - 0x933baffc  libsystem_kernel.dylib (2050.18.24) <C17D49D0-7961-3B67-B443-C788C6E5AA76> /usr/lib/system/libsystem_kernel.dylib
0x933bb000 - 0x933bbfff  libSystem.B.dylib (169.3) <81C58EAB-0E76-3EAB-BDFD-C5A6FE95536F> /usr/lib/libSystem.B.dylib
0x933bc000 - 0x933c9ff7  com.apple.AppleFSCompression (49 - 1.0) <166AA1F8-E50A-3533-A3B5-8737C5118CC3> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x933ca000 - 0x937e7fff  FaceCoreLight (2.4.1) <571DE3F8-CA8A-3E71-9AF4-F06FFE721CE6> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
0x937e8000 - 0x937eefff  libGFXShared.dylib (8.6.1) <E32A7266-FCDD-352C-9C2A-8939265974AF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x93900000 - 0x93a89ff7  com.apple.vImage (6.0 - 6.0) <1D1F67FE-4F75-3689-BEF6-4A46C8039E70> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x93ed3000 - 0x93f7dfff  com.apple.LaunchServices (539.7 - 539.7) <AF33EBD3-BC0B-30B5-B7DA-5CCCF12D7EDD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x93f7e000 - 0x93f85ff3  com.apple.NetFS (5.0 - 4.0) <1F7041F2-4E97-368C-8F5D-24153D81BBDB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x93f86000 - 0x93f89ff7  libcompiler_rt.dylib (30) <CE5DBDB4-0124-3E2B-9105-989DF98DD108> /usr/lib/system/libcompiler_rt.dylib
0x93f8a000 - 0x94172ff3  com.apple.CoreFoundation (6.8 - 744.12) <E939CEA0-493C-3233-9983-5070981BB350> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x94178000 - 0x94276ff7  libFontParser.dylib (84.5) <B3006327-7B2D-3966-A56A-BD85F1D71641> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x942d5000 - 0x942ddfff  com.apple.DiskArbitration (2.5.1 - 2.5.1) <25A7232F-9B6A-3746-A3A8-12479D086B1E> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x942de000 - 0x942dffff  libsystem_sandbox.dylib (220) <4E42390B-25EC-3530-AF01-337E430C16EB> /usr/lib/system/libsystem_sandbox.dylib
0x942e0000 - 0x94377ff7  com.apple.ink.framework (10.8.2 - 150) <D90FF7BC-6B90-39F1-AC52-670269947C58> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x94378000 - 0x9437cfff  com.apple.IOSurface (86.0.3 - 86.0.3) <E3A4DB0A-1C1A-31E3-A550-5C0E1C874509> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x9437d000 - 0x943a2ffb  com.apple.framework.familycontrols (4.1 - 410) <5A8504E7-D95D-3101-8E20-38EADE8DEAE1> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x943a3000 - 0x943a3fff  com.apple.CoreServices (57 - 57) <956C6C6D-A5DD-314F-9C57-4A61D41F30CE> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x943a4000 - 0x9440cff7  com.apple.framework.IOKit (2.0 - 755.18.10) <9A80E97E-544F-3A45-916D-6DB7ED217E33> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x9440f000 - 0x9440fffd  libOpenScriptingUtil.dylib (148.2) <907E25B1-4F50-3461-B8D5-733C687EB534> /usr/lib/libOpenScriptingUtil.dylib
0x94410000 - 0x94414ffc  libGIF.dylib (845) <714E9F0D-D7A3-3F58-B46E-FCBE0F144B23> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x94415000 - 0x94423fff  com.apple.opengl (1.8.6 - 1.8.6) <1AD1AE7B-B57B-35B5-B571-32A34F0DA737> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x94470000 - 0x94474fff  com.apple.OpenDirectory (10.8 - 151.10) <A1858D81-086F-3BF5-87E3-9B70409FFDF6> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x94478000 - 0x944dcfff  com.apple.datadetectorscore (4.0 - 269.1) <4D155F09-1A60-325A-BCAC-1B858C2C051B> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x944dd000 - 0x944e8fff  libcommonCrypto.dylib (60026) <A6C6EDB8-7E69-3827-81F3-9A74D0935461> /usr/lib/system/libcommonCrypto.dylib
0x95453000 - 0x954bbfe7  libvDSP.dylib (380.6) <55780308-4DCA-3B10-9703-EAFC3E13A3FA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x955d5000 - 0x958daff7  com.apple.CoreServices.CarbonCore (1037.3 - 1037.3) <4571EDDC-704A-3FB1-B9A6-59870AA6165F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x958db000 - 0x9590cfff  com.apple.DictionaryServices (1.2 - 184.4) <0D5BE86F-F40A-3E39-8569-19FCA5EDF9D3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x9590d000 - 0x95919ff7  com.apple.NetAuth (4.0 - 4.0) <4983C4B8-9D95-3C4D-897E-07743326487E> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x95940000 - 0x9598fff6  libTIFF.dylib (845) <989A2EB9-3A49-3157-8E9C-B16E6005BC64> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x95990000 - 0x9599eff7  libz.1.dylib (43) <245F1B61-2276-3BBB-9891-99934116D833> /usr/lib/libz.1.dylib
0x9599f000 - 0x959a6ffb  libunwind.dylib (35.1) <E1E8D8B3-3C78-3AB1-B398-C180DC6DCF05> /usr/lib/system/libunwind.dylib
0x95c00000 - 0x95ea3ffb  com.apple.CoreImage (8.2.2 - 1.0.1) <85BFFB09-D765-3F5F-AF65-FB136DDCAEF3> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x96aff000 - 0x96b2bff7  libsystem_info.dylib (406.17) <AA5611DB-A944-3072-B6BE-ACAB08689547> /usr/lib/system/libsystem_info.dylib
0x96b2c000 - 0x96bdbff7  com.apple.CoreText (260.0 - 275.16) <873ADCD9-D361-3753-A220-CDD289196AD8> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x96bdc000 - 0x96bdcfff  com.apple.ApplicationServices (45 - 45) <677C4ACC-9D12-366F-8A87-B898AC806DD9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x96ead000 - 0x9716dfff  com.apple.security (7.0 - 55179.1) <CB470E48-621B-34D9-9E78-8B773358CB6B> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x97171000 - 0x971d3fff  libc++.1.dylib (65.1) <C0CFF9FF-5D52-3EAE-B921-6AE1DA00A135> /usr/lib/libc++.1.dylib
0x971d4000 - 0x9722bff7  com.apple.ScalableUserInterface (1.0 - 1) <2B5E454B-BC49-3E85-B54D-1950397C448C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x97303000 - 0x973f4ffc  libiconv.2.dylib (34) <B096A9B7-83A6-31B3-8D2F-87D91910BF4C> /usr/lib/libiconv.2.dylib
0x97a82000 - 0x97a84fff  libdyld.dylib (210.2.3) <05D6FF2A-F09B-309D-95F7-7AF10259C707> /usr/lib/system/libdyld.dylib
0x9818d000 - 0x981a2fff  com.apple.speech.synthesis.framework (4.1.12 - 4.1.12) <DE68CEB5-4959-3652-83B8-D2B00D3B932D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x98255000 - 0x98258ff7  com.apple.TCC (1.0 - 1) <437D76CD-6437-3B55-BE2C-A53508858256> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x98260000 - 0x98643ff3  com.apple.HIToolbox (2.0 - 625) <5A312E41-9940-363E-B891-90C4672E6850> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x98644000 - 0x9872dff7  libxml2.2.dylib (22.3) <015A4FA6-5BB9-3F95-AFB8-B9281E22685B> /usr/lib/libxml2.2.dylib
0x9872e000 - 0x987e2fff  com.apple.coreui (2.0 - 181.1) <C15ABF35-B7F5-34ED-A461-386DAF65D96B> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x987e3000 - 0x987ecff9  com.apple.CommonAuth (3.0 - 2.0) <A1A6CC3D-AA88-3519-A305-9B5D76C5D63B> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x987f9000 - 0x98816fff  libCRFSuite.dylib (33) <C9D72D0C-871A-39A2-8AFB-682D11AE7D0D> /usr/lib/libCRFSuite.dylib
0x98a78000 - 0x98b85057  libobjc.A.dylib (532.2) <FA455371-7395-3D58-A89B-D1520612D1BC> /usr/lib/libobjc.A.dylib
0x98c83000 - 0x98e3fffd  libicucore.A.dylib (491.11.1) <B19E450A-BAF1-3967-9C95-7F77DC0B4639> /usr/lib/libicucore.A.dylib
0x98e4f000 - 0x98f47ff9  libsqlite3.dylib (138.1) <AD7C5914-35F0-37A3-9238-A29D2E26C755> /usr/lib/libsqlite3.dylib
0x98f48000 - 0x98f89ff7  libcups.2.dylib (327) <F46F8703-FEAE-3442-87CB-45C8BF98BEE5> /usr/lib/libcups.2.dylib
0x98f8a000 - 0x98fc9ff7  com.apple.bom (12.0 - 192) <0637E52C-D151-37B3-904F-8656B2FD44DD> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x98fcb000 - 0x98ff8ffb  com.apple.CoreServicesInternal (154.2 - 154.2) <DCCF604B-1DB8-3F09-8122-545E2E7F466D> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x98ff9000 - 0x9903bff7  libauto.dylib (185.1) <B2B5B639-6778-352A-828D-FD8B64A3E8B3> /usr/lib/libauto.dylib
0x9903c000 - 0x99061ff7  com.apple.CoreVideo (1.8 - 99.3) <5B872AC0-E82D-3475-A3F9-FD95F380560D> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x99062000 - 0x99063fff  libDiagnosticMessagesClient.dylib (8) <39B3D25A-148A-3936-B800-0D393A00E64F> /usr/lib/libDiagnosticMessagesClient.dylib
0x990de000 - 0x99107fff  libxslt.1.dylib (11.3) <0DE17DAA-66FF-3195-AADB-347BEB5E2EFA> /usr/lib/libxslt.1.dylib
0x993ae000 - 0x99412ff3  libstdc++.6.dylib (56) <F8FA490A-8F3C-3645-ABF5-78926CE9C62C> /usr/lib/libstdc++.6.dylib
0x99413000 - 0x99421ff3  libsystem_network.dylib (77.10) <7FBF5A15-97BA-3721-943E-E77F0C40DBE1> /usr/lib/system/libsystem_network.dylib
0x9943f000 - 0x994d9fff  com.apple.CoreSymbolication (3.0 - 87) <6A27BBE5-6EF0-3D5D-A485-2145826B9796> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x995ae000 - 0x995b2ffe  libcache.dylib (57) <834FDCA7-FE3B-33CC-A12A-E11E202477EC> /usr/lib/system/libcache.dylib
0x9960a000 - 0x99684ff7  com.apple.securityfoundation (6.0 - 55115.4) <A959B2F5-9D9D-3C93-A62A-7399594CF238> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x99685000 - 0x99691ff8  libbz2.1.0.dylib (29) <7031A4C0-784A-3EAA-93DF-EA1F26CC9264> /usr/lib/libbz2.1.0.dylib
0x99692000 - 0x9969cfff  libsystem_notify.dylib (98.5) <7EEE9475-18F8-3099-B0ED-23A3E528ABE0> /usr/lib/system/libsystem_notify.dylib
0x9969d000 - 0x997a8ff7  libJP2.dylib (845) <D409C913-6FA4-3D60-BFE0-B9FC6A02FEE0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x997a9000 - 0x9a365ffb  com.apple.AppKit (6.8 - 1187.34) <06EDB1D1-3B8A-3699-8E3A-D8F50A27AB7C> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x9a366000 - 0x9a424ff3  com.apple.ColorSync (4.8.0 - 4.8.0) <EFEDCB37-4F20-3CEC-A185-5D2976E11BAC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x9a4a2000 - 0x9a4f0ff3  com.apple.SystemConfiguration (1.12.2 - 1.12.2) <7BA6C58B-0357-356F-BB69-17ACB5E35988> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x9a502000 - 0x9a64fffb  com.apple.CFNetwork (596.2.3 - 596.2.3) <1221EF86-659B-3136-AB57-0CC6B130CDA2> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x9a650000 - 0x9a694fff  libGLU.dylib (8.6.1) <06BAFDCA-800C-35E3-B1A3-F05E105B86AB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x9a695000 - 0x9a69cfff  libsystem_dnssd.dylib (379.32.1) <6A505284-2382-3F27-B96F-15FFDACF004E> /usr/lib/system/libsystem_dnssd.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 2
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 1334
    thread_create: 2
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=113.6M resident=68.8M(61%) swapped_out_or_unallocated=44.8M(39%)
Writable regions: Total=111.1M written=3424K(3%) resident=21.3M(19%) swapped_out=0K(0%) unallocated=89.9M(81%)
REGION TYPE                      VIRTUAL
CG backing stores                   980K
CG image                              4K
CG shared images                   1184K
CoreServices                       3696K
MALLOC                             83.3M
MALLOC guard page                    48K
Memory tag=240                        4K
Memory tag=242                       12K
Memory tag=35                      7476K
Stack                              65.5M
VM_ALLOCATE                        16.1M
__DATA                             5124K
__DATA/__OBJC                       140K
__IMAGE                             528K
__LINKEDIT                         31.2M
__OBJC                             1528K
__OBJC/__DATA                        40K
__PAGEZERO                            4K
__TEXT                             82.4M
__UNICODE                           544K
mapped file                       123.7M
shared memory                       308K
TOTAL                             423.3M
Model: MacBookPro10,1, BootROM MBP101.00EE.B02, 4 processors, Intel Core i7, 2.3 GHz, 16 GB, SMC 2.3f32
Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In, 512 MB
Graphics: NVIDIA GeForce GT 650M, NVIDIA GeForce GT 650M, PCIe, 1024 MB
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D5434314753364D465238432D50422020
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D5434314753364D465238432D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xEF), Broadcom BCM43xx 1.0 (5.106.98.81.22)
Bluetooth: Version 4.0.9f33 10885, 2 service, 18 devices, 1 incoming serial ports
Serial ATA Device: APPLE SSD SM256E, 251 GB
USB Device: Elements 1042, 0x1058  (Western Digital Technologies, Inc.), 0x1042, 0x14a00000 / 1
USB Device: hub_device, 0x8087  (Intel Corporation), 0x0024, 0x1a100000 / 2
USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8510, 0x1a110000 / 3
USB Device: hub_device, 0x8087  (Intel Corporation), 0x0024, 0x1d100000 / 2
USB Device: hub_device, apple_vendor_id, 0x9126, 0x1d110000 / 6
USB Device: Intuos5 touch M, 0x056a  (WACOM Co., Ltd.), 0x0027, 0x1d112000 / 7
USB Device: Babyface (23152215), 0x0424  (SMSC), 0x3fc7, 0x1d111000 / 14
USB Device: Wacom Wireless Receiver, 0x056a  (WACOM Co., Ltd.), 0x0084, 0x1d113000 / 13
USB Device: Apple LED Cinema Display, apple_vendor_id, 0x9226, 0x1d116000 / 12
USB Device: Display iSight, apple_vendor_id, 0x8508, 0x1d115000 / 11
USB Device: Display Audio, apple_vendor_id, 0x1105, 0x1d114000 / 10
USB Device: hub_device, 0x0424  (SMSC), 0x2512, 0x1d180000 / 3
USB Device: BRCM20702 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x1d181000 / 5
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8286, 0x1d181300 / 9
USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0263, 0x1d182000 / 4
Re: Fireface USB Settings quit unexpectedly
I have the exact same crash on thread 0
Reported some days ago, but for me the interface does not work when I wake the mac from sleep and find the crash log.
Have to "sudo killall coreaudiod"..
Yan Maresz
Parent Process:  launchd [183]
User ID:         501
Date/Time:       2012-09-26 03:42:47.732 +0200
Report Version:  10
Sleep/Wake UUID: 73AE42DB-FE36-44BC-8836-6C93EEFA9926
Interval Since Last Report:          76442 sec
Crashes Since Last Report:           1
Per-App Crashes Since Last Report:   1
Anonymous UUID:                      06562D66-FACE-71EC-E661-6CFAD9DB7230
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000080000020
VM Regions Near 0x80000020:
    VM_ALLOCATE            0000000003a7d000-0000000004a79000 [ 16.0M] rw-/rw- SM=ALI
    __TEXT                 000000008fe94000-000000008fec7000 [  204K] r-x/rwx SM=COW  /usr/lib/dyld
0   libobjc.A.dylib                   0x90947a87 objc_msgSend + 23
1   com.apple.CoreFoundation          0x9498d7a2 CFNumberGetValue + 130
3   de.rme-audio.Fireface_USB_Settings    0x00003254 CHardware::LoadSettings(int) + 152
6   libobjc.A.dylib                   0x909605d3 -[NSObject performSelector:withObject:] + 70
7   com.apple.Foundation              0x91f990c0 __NSThreadPerformPerform + 395
8   com.apple.CoreFoundation          0x9498d66f __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 15
9   com.apple.CoreFoundation          0x9498d099 __CFRunLoopDoSources0 + 233
10  com.apple.CoreFoundation          0x949b2e46 __CFRunLoopRun + 934
11  com.apple.CoreFoundation          0x949b263a CFRunLoopRunSpecific + 378
12  com.apple.CoreFoundation          0x949b24ab CFRunLoopRunInMode + 123
13  com.apple.HIToolbox               0x90ae715a RunCurrentEventLoopInMode + 242
14  com.apple.HIToolbox               0x90ae6ec9 ReceiveNextEventCommon + 374
15  com.apple.HIToolbox               0x90ae6d44 BlockUntilNextEventMatchingListInMode + 88
16  com.apple.AppKit                  0x92966a3a _DPSNextEvent + 724
17  com.apple.AppKit                  0x9296626c -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 119
18  com.apple.AppKit                  0x9295c6cc -[NSApplication run] + 855
19  com.apple.AppKit                  0x928ff6f6 NSApplicationMain + 1053
May I add that this crash happens every day on wake from sleep !
I don't send the crash log, they are identical to the one above with :
best
Yan
4 (edited by oblique strategies 2012-10-28 22:38:29)
Are you also running the interface via the built-in USB port in a Cinema Display?
5 (edited by nitemole 2012-10-26 22:53:36)
oblique strategies wrote:
Are you also running the interface via the built-in USB hub in a Cinema Display?
I experience the same crash than yanmaresz over and over. FWIW, the FFUC is plugged directly into my late 2011 27" iMac (OS X 10.8.2).
6 (edited by oblique strategies 2012-11-09 13:06:03)
I've seen this combination a few times in my Console Messages recently, but I haven't noticed if it was associated with a crash of any kind.
11/9/12 2:07:31 AM    Fireface USB Settings[1077]    resetFirefaces
11/9/12 2:07:32 AM    Fireface USB Settings[1077]    NumDevs = 1
Anyone have an explanation of what these message means?
Specs:
MacBook Pro early 2008
OS X 10.6.8
Fireface UC
