Topic: UFX: Output Mix Controls Disabled When Using USB. Normal?
I've wondered a couple of times why are output mix controls disabled when the unit is connected to computer (I'm using USB). Is it normal? As soon as I unplug USB cable, output mix controls are enabled.
By output mix controls I mean the Vol and Pan controls on the unit when you press Channel and scroll to any output with knob 1 and choose any of the Mix tabs (Mix - Analog In, Mix - AES In, Mix - ADAT In) with knob 2. When scrolling through the controls by pressing knob 2, all Vol and Pan controls are disabled (gray background).
