Topic: Newbie Qn - XLR to TS Query
Just got my UFX :-) Loving it - initially setup was delayed and I started to get frustrated as the routing didn't appear to be working as it should based on what I'd read - then after 10 minutes I noticed that master volume of the synth I was using to test my routing was all the way down :oops. Everything started working fine when I fixed that.
Two questions re TS/TRS/XLR cabling. I have a AT-45 Organ that has TS inputs and TS outputs. Would using a XLR to TRS cable from the UFX main outs to these inputs be likely to damage either the UFX or the organ? And presumably if I replace them with XLR to TS cables that would then be OK ?
Similar question for using TS to TS cable to connect the organ outputs to the UFX's TRS inputs on the rear (1-8)? Or should I go to the front panel's combo inputs 9-12?:o
