Topic: TouchOSC does not receive OSC from TotalMixFX after restart
Hi guys,
I'm using a Babyface with TotalMixFX 0.984, Windows 7 64bit pro, Connectify Lite and iPad 3 with iOS 6 and current TouchOSC (1.8.1 afaik).
I'm having the problem that after restarting, TotalMixFX correctly receives data from TouchOSC but the other way round does not work. After changing the ports, everything is fine again.
Any ideas?
Thanks in advance,
BurtaN
OSCAR for Android and iOS with TotalMixFX templates: http://www.oscar-app.de
Re: TouchOSC does not receive OSC from TotalMixFX after restart
Ok, it is enough to change the port in TotalMixFX and change it back to the original state after restarting. It seems that the port TotalMixFX uses must be "resetet" after restart to work.
I've got huge problems now receiving OSC data from TotalMixFX to my iPad. Surprisingly, my Galaxy Nexus with the TouchOSC version for android works fine. I think the problem is my iPad. It's version 3 with iOS 6.0.0. Anyone else experiencing problems with that device?
Thanks in advance!
Ok, the problem seemed to be iOS 6.0.0 and its WPA2 problems. Got 6.0.1 and it's fine until now... smile
