Topic: DIGI9636 with Windows 8 - 32 bit
OK so the driver shows up, says all is ok but no sound - nothing!
HELP!
Re: DIGI9636 with Windows 8 - 32 bit
Please be more specific - what kind of audio software did you try? Please test ASIO programs like Reaper or others. What is the card connected to, where is there "no sound"?
3 (edited by satyagraha 2012-11-09 10:18:27)
Thanks Daniel
Ok to be precise. We have Cubase Elements 6. The RME card is fed into a Behringer 3216 via ADAT interface.
In Cubase/VST connections, initially the Audio Device shows 'Not Connected', and, though when you click it you are offered the option of 'ASIO DIGI9636/52', you cannot select the ASIO interface.  I am running v2.11 of the driver - in the Windows device manager, 'RME DIGI9636' shows up under 'Sound, video and game devices' but when I go to control panel and select 'Sound/Manage Audio Devices', playback and recording shows 'No audio devices are installed'.
I hope you can help - this is driving me nuts!
Mark McGlynn
Can't quite follow - what exactly is it you "cannot select"? A screenshot might help illustrate the problem.
