Topic: Creating Default Mixer for All Users
I work in a Windows 7 multi user environment with a Fireface UC
It would help us if we could set up a default mixer/snapshot that would be loaded for all users.
I've found the xml files in :C:\Users\user\AppData\Local\TotalMixFX
But for a new user - how are these created ?
Or where are they copied from ?
I can't find any global default in the usual "all users" areas.
2 (edited by rod_f 2012-11-08 18:16:22)
Re: Creating Default Mixer for All Users
And how do I create a suitable default so that all users will inherit it without any input by them.
I have a large number of broadly non-technical people who will use the PC and my intention is to have it set up appropriately for them.
And each will logon to Windows as a different user.
3
Store a workspace, as file and directly via hotkey W.
Edit: I see. Still not sure what you mean exactly. You could just copy your favorite settings (file) into all the user directories.
My problem is managing the numbers - there are actually 6 PCs with Firefaces in them and 50-60 users who each have their own windows 7 login.
Each user won't have logged in to every computer so the profiles have not been created on every machine.
And I can't predict which PC they will use next.
So I would like a global default snapshot or workspace that I can create which will automatically be applied to every current and new user.
Is this possible ?
5
Sorry, I am no specialist for that. Maybe by copying a suitable default file into the All Users path will do so. But I am not even sure when Windows (and TM FX) would use that path.
Ok, I realise that it is a bit of an obscure request.
One final question: can I load a snapshot or workspace via the Windows "command line" ?
So that I could write a batch file that loaded on login.
ie something like
d:\rme_loadworkspace_command.exe /mypreset.tmws
Thanks for your help
7
Basically yes. TMWS files are registered in the system, double clicking on them will start TM FX and load the file.
That probably is the solution.
Although annoyingly the files aren't already associated - and associating them myself only works in my "user" account.
Maybe whoever installed the device didn't have all the admin rights ??
Anyway, the vagaries of corporate Windows 7 aren't your fault so thanks for the help.
A simple batch file placed in the startup folder like this:
c:\windows\system32\TotalMixFX.exe D:TotalMix_init.tmws,
will load the workspace totalmix_init.tmws (found in the root of the D drive) on login of the PC. So far so good.  However because TotalMixFx is changing workspaces, it then throws up an error asking "discard changes". This could be alarming in a multi-user environment where most are non technical.  Is there a way of supressing the error message - say with a command line switch?  Any help would be much appreciated
