Topic: Fireface 800 Headphone output stopped working on one side.
I have been using a Fireface 800 with a Mac for over 4 years of untroubled constant use, but I turned it on yesterday and one of the Headphone channels was missing (left side I think). The headphones work in a different amp so I have eliminated those from the equation. Everything else is the same as before the failure so I can only conclude it is a hardware issue :-(
I did check routing and the headphones output in totalmix is showing both channels working and the main outputs 1&2 are working normally.
Where in the UK is the best place to get it repaired?
Re: Fireface 800 Headphone output stopped working on one side.
Please contact Synthax UK. They will, however, send the unit to Germany.
http://www.synthax.co.uk/RMA
