Topic: Babyface left XLR Output connection problem - new breakout box?
Hello!
The left XLR Output of my Babyface's breakout box is not working properly - it makes noises that suggest it does not connect well. I opened the XLR connector and everything seems to be OK. I then tried twisting a little bit the cable near the connector and the noises come and go, which suggests that probably it's the cable's fault.
Is this something that can be fixed, or it is better to just order a replacement breakout box?
Cheers!
Re: Babyface left XLR Output connection problem - new breakout box?
You can exchange the breakout cable at your local dealer or distributor.
