Topic: Connecting two fireface 400 on Macbook Pro
I need to connect two fireface 400 on a macbook pro 2.16 intel core 2 duo laptop. I also use Ableton 8.
1. Can you describe the steps I have to follow in order to connect and sync them together and be able to have all inputs and outputs available?
2. Is my laptop powerful enough to have both cards connected? Will I encounter any problems?
Thanks a lot for your help!
Re: Connecting two fireface 400 on Macbook Pro
1. You will need to create an aggregate device and sync the units with Word Clock. Alternatively, configure one of them as standalone converter (see manual) and connect via ADAT.
2. Looks ok in terms of bare specs.
