Topic: Fireface UFX multitrack DURec PLAY
Hi everybody
I'm a new UFX user so be patient.
After recording a multitrack session I'm not able to listen all the track in play mode at headphone or monitor output.
Any suggestion?
Tks Max
Re: Fireface UFX multitrack DURec PLAY
Hi Max,
How are you going about this? Are you using TMFX on a connected computer, or using the UFX stand alone? You are talking about the DURec recording from a USB device connected to the front panel, correct?
3
You have to set all your DURec tracks in TotalMix to different inputs, then mix down those signals to the phones output.
TKS for the answers, I will try again as you suggest and ....... report
MJ
It works!
I understand if I record 5 tracks on channels 1 3 5 10 13 I have to set  the play button of these channels on 1 2 3 4 5 to listen the recorded files.
A little bit tricky but it works.
Tks again
Max
