Topic: ucx - too much gain when recording
Hi folks, I recently bought a UCX and am only starting to learn how to use it. ed:
Here's my question: I am recording vinyl using the front 1 and 2 xlr inputs, but I end up with too much gain with Totalmix set at 10, which is apparently the minimum. Entering a gain value below 10 always brings back the number 10, seems it accepts only values starting with 10 or higher.  I don't want to use 'autoset' as that reduces the gain too much. Also for information, I cannot reduce the output signal on my phono preamp therefore have to do this on the Ucx. How can I solve this? Thanks a lot, and please forgive my ignorance.
Roberto
Re: ucx - too much gain when recording
Use one of the line inputs... If levels are still high, set to +4...
