1 (edited by s0415 2012-12-06 19:13:01)
Topic: Line6 POD Farm2 SampleRate Fixing Error with RME Fireface series
Hello My RME ^^
Point : Line6 Farm2 (http://line6.com/podfarm/) is Always Automatically Set to ONLY 44.1Khz Sample Rate and Fixed!
          If When selected USB Device set to RME FireFace series on WIndows7.
           I want SampRerate set to 48Khz and other !
           But! If When i have select USB Device set to POD Pro series
           POD Farm2 and SampleRate setting goes to Works Fine!  Everything is Good!
http://line6.com/support/servlet/JiveSe … R_Win7.jpg
I'm  Studio Session Guitar Player. I am fighting with this little problem a year ago.
RME Fireface Interface HI-Z jack until I have time to upgrade to the POD HD PRO POD FARM2 Input PreAmp recording has.
However, I still think the quality is good. RME AD converters of the AD converters than LINE6
But.POD Farm 2 Standalone and chemistry with RME Fireface series does not fit the bugs fixed sample rate to 44khz.
Therefore, I was able to use only the POD FARM 2 Plugin.
I want to fix the problem this time.
I have tested with....
POD HD PRO , POD XT PRO , RME FireFace 400(fw) , RME FireFace UC(Usb) on Windows XP. WIndows7, OSX 10.7.4 OSX.10.6.8
on Inte base PC , Inte base MAC PRO and MacBook Pro , Of course, using the latest drivers and firmware Until today.
I think. This problems is only for Windows ( OSX is works fine)
Do you Have IDEA ??????
Please Help me and God Bless you ^^
http://line6.com/support/servlet/JiveSe … 2_Win7.jpg
Re: Line6 POD Farm2 SampleRate Fixing Error with RME Fireface series
You will need to see whether it is possible to set 48k in your software. If it is fixed to 44k, then there is no solution.
3 (edited by s0415 2012-12-07 17:29:47)
Thx .
Yes. I can change to set 48Khz and more in DAW (Nuendo.Protools etc...)
But Still Automatically Fixed again to 44Khz by"FirefaceUSB settings Controll Panel"
( as you can see I couldn't Modifiy the other SampleRate anymore when "FirefaceUSB settings Controll Panel" is fixing)
What You think this problem by whom?
RME? Line6? Microsoft?
I'm goes to be carzy.....T.T Help me Please.....DeadHorse
GOD bless you ^^
