Topic: fireface ucx: max echo time + effects midi remote
Dear forum,
I own a fireface uc and I am really glad with it.
I am considering buying second fireface and aiming for ucx because of the effects.
I've the following questions:
How long is the maximum delay time of the echo effect?
Does that depend on other things, e.g. the actual sampling rate?
How much compressors can be instantiated?
Does the effects (compressors) work at 192khz if that sampling rate is used?
Are the effect-parameters like delay time of the echo-effect controllable via midi?
Is it possible to interface a 16bit/44.1khz devices via spdif and/or adat while using the internal engine at 192khz?
Thank you very much in advance!
