Topic: Reall,really loud clicks when using TouchOSC (Reason Retouch) via wlan
High People,
I have a fireface 400 and running Reason 6.5 on a Windows 7 64 bit PC. I finally got Reason running together with the so called Retouch Duo from Retouch control.com on my iPad 2 via adhoc over wlan.
It's working, i can move faders and stuff but every few minutes (every 60-70 seconds) i get a very loud click on my Speakers and in this state it's not usable.I'm very sure it's the Fireface because i have the same Problem with Network over cable and everytime i use Reason i disable the Network driver and it's ok then.
I tried to raise the buffer to 256 Samples, it's the same, maybe not as often as with 128 Samples, but i'm not really sure.
The other thing i thought could help is to lower the channel bandwidth (disable some AdatChannels).
Does anybody have the same problem, is there a solution for it?
Oh, i forgot to mention that i have a TP Link TL-WN8221n on an usb port.
Regards, Meik
