Topic: no sign of totalmix after loading on windows 7
hi all,
After loading drivers for babyface on pc, windows 7 i cannot locate totalmix. When i search computer i get the "No items match your search" message.
I have loaded the drivers through the device manager as recomended for windows and all is good "latest drivers have loaded successfully". however, i feel the drivers are not loading correctly as there is no sign of totalmix anywhere. Some help is much appreciated.
basil, uk
Re: no sign of totalmix after loading on windows 7
More details, please. Which device, which driver, etc..
hi daniel,
Babyface driver version is 1.0.28.0 and totalmix product version is 0.0.98.9. After reading another post in the forum I have located totalmix in c/windows/system32/totalmix and pinned it to my taskbar and start up menu. All is working (record/playback etc) however, the big volume encoder is not responding or adjusting any levels when i select in/out /phones, nothing at all only thing that works with the large encoder is the dim when i press it in. I have assigned mains out to AN 1/2 and phones to PH 3/4 and also tried the total reset and still no communication with the big volume encoder. I am on pc/windows 7 /samplitude.
regards, basil
Maybe you need to update the firmware of the Babyface. Otherwise it looks like it's broken.
