Topic: Midi issue, Babyface
Hi there,
Lately I wanna control my Moog Midi MuRF by midi signal. I connected the midi-out port of the breakout cable to the Moog's midi-in with a well functional midi cable, but it didn't work. I try to rule out where the problem is, changed several midi cables, try to update Moog MuRF's firmware then try to connect MuRF with my Korg padKontrol, so lucky it got a midi-out port with it. So I did an A/B test with the Korg device, and it worked!!
Therefore I'm pretty sure there must be something wrong with my Babyface setting, the cable is okay, the Moog MuRF work okay, my computer is okay, the MIDI channel selection is totally okay. I rarely possible break my breakout cable, never touch it and I recorded with two mics days ago and sounds no problem. Maybe I messed up the MIDI setting someday. Please help me to figure out. Your help is appreciated.
THX!
