Topic: Fireface UC "forgets" settings after Ruhezustand, Win8
Hello
I up-grated to win8 and i´m using JRiver with a Fireface UC to listen my music.
Since using Win8 the FF erases his settings after the laptop returns from "Ruhezustand"
The "snapshot" function can not restore the settings. Also not working is Reset Mix, total reset. Still no output.
The only what helps up to know is deinstall FF in Device Manager, restart and install the drivers new.
Any tip what I can do? Firmware and Driver are the most actual.
Greezt
Uwe
Re: Fireface UC "forgets" settings after Ruhezustand, Win8
Wait, "Still no output" is not true. I have a signal on the monitor and I can see it in the level-meters from TotalMix FX.
But I can not influence it. The volume is not reacting and also if i "mute" there is no change in the signal.
Greetz
Uwe
3
Makes no sense to me. Unplug the UC, wait 5 seconds - replug should do it. Or switch off power at the UC for 5 seconds.
On my laptop under W8 everything works as expected.
@MC
thanks, plug/unplug is working.
Switch off power makes a strong "Plopp" in my speakers.
thanks
Uwe
