Topic: ufx vs rme 800
hello
is there a big diference between the firewire 800 on the rme 800 and the firewire 400 on the ufx?  or is usb faster?
thanks!
Re: ufx vs rme 800
Firewire800 always was only used when using 2 fireface 800 at the same time.
Drivers are different and hardware too, so there will be a difference.
In real life firewire is always more stable when you have the right firewire chip in your system (which is not expensive, but might not already be implemented on your motherboard)
