Topic: Fireface UCX - Incorrect Latency (Logic Ping)
Just bought a UCX over christmas for use with my Digiface (adat in/out 2).
However, Logic is giving me incorrect Ping and click-based Loopback results, with outputs 5-6 on the UCX looped-back to inputs 5-6.
Logic is reporting a Ping/offset of +1 when the UCX is running from it's USB drivers, as clock master.
Also, when running the UCX from the Digiface (with UCX as adat "slave", either as clock master or slave), Logic is reporting a Ping/offset of +48 samples, 20 more than it should be. According to this thread ADAT Latency - Fireface UCX, Logic should be reporting a Ping/offset of no more than 28 samples (21 for AD/DA, and 7 or less for TM FX).
The only sample rates that are showing a ping of 0 are 88.2k and 96k. 44.1k, 48k, 176.4k and 192k all show a ping/offset of +1. Digital/SPDIF loopback is reporting a ping of -20 samples, and ADAT loopback is reporting -21 samples.
I am testing the latency from a completely empty Logic project, with absolutely no other plugins running. I've completely removed the drivers & preferences, and tried installing UCX drivers 1.68, 1.76 and 1.78, and refreshed the firmware. None of this has helped. Incidentally, when I ran a UFX from the same Mac in November, the UFX correctly reported a ping of 0. Nothing on my Mac has changed since then (Logic version the same, OS X version the same).
Logic should be reporting a ping/offset of 0 from it's USB drivers. And 28 or less when hanging off the Digiface...
Please help, this is a head scratching problem.
Screen shots attached below.
Thanks,
D
Digiface <-> [Fireface UCX & Prism Orpheus - ADAT]
