Topic: FF UC on Win 8 and default sound device
I went to a new computer with Win8. Setup of my Fireface UC went smoothly, everything works.
But:
My Fireface is plugged into a switchable power bar, together with some active monitor speakers. I'm not using this sound rig all the time the computer is switched on. So I thought it sensible to power it up separately and only when needed.
With Windows 7 and my old computer this worked very well. But not so anymore with Windows 8. Now every time I switch on the Fireface, the analog output pair 7+8 of the Fireface (which is the headphone socket) becomes the default audio playback device.
This may be a desirable behaviour for the average user who occasionally plugs in his USB headset, but not for me. I like my monitor speakers (and thus the Fireface) dedicated to music. I want bit-transparent sound, untouched by Windows' internal remixing/resampling functions. All other sound (youtube, system sounds etc.) should go to the built in sound device of my motherboard, therefore this should remain the default.
Here are my questions:
1. Is this behaviour (newly plugged in USB sound devices become the default playback device) defined by Windows 8?
2. If so, can this be changed by the user?
3. Can this be initiated (or better 'prevented' in my case) by the device driver of the sound device in question?
4. Are there other known solutions to this problem?
5. Could an addition be made to TotalMix, providing a choice to the user if the Fireface shall be default device (and which stereo pair shall be the front speakers)?
My own research into the matter turned up only this, which may probably help someone with the same or similar problem: http://www.daveamenta.com/2011-05/progr … windows-7/
This one works with device numbers, they are different on every system and subject to change when a new sound device gets installed. Every one who wants to use this has to adapt it to his or her individual system.
Windows 8 Pro 64 bit
Fireface UC, Firmware 117, driver 1.028
