Topic: FireFace UCX - is this Routing possible ?
Hi RME
I’ll keep this as simple as I can.
I have a 3 Track Song in Presonus Studio One 2.5
Studio One 2.5 Track 1 is Vox
Studio One 2.5 Track 2 is Acoustic Guitar
Studio One 2.5 Track 3 is “ Guitar Rig “ on a clean Telecaster setting
My Main Master Outs are 5 + 6
The Electric Guitar used for Track 3 is plugged in to the UCX Mic 1 input
On Playback, all is fine.
However ….. as I do a lot of Input Monitoring what I want to do is:-
- keep everything going out to the Master 5 + 6
and at the same time
- simultaneously also send the wet-effect’ed live-guitar-rig-signal out through its own separate output [ say Output 3 ] to my monitoring mixer
With the above, I can set the Mix Playback as I want it and then when I go to record the guitar-rig-electric guitar I can monitor control its wet-only-signal to my liking without changing any of the Mix playback settings
Can someone please advise
a - can the above be done
and
b – if so, what I the easiest way to do it ?
Thanks,
Ben
