Topic: UFX as a playback device ?
hi.. im interested in the possibility of using a UFX as a playback device for backing tracks alongside a band.. I would like to keep a computer out of the setup. Ideally i want to be able to put a thumb drive in the ufx, select a song and hit play with 6-8 seperate tracks playing back (ie: click track, keyboards, backing vocals, sound FX etc) and have all those tracks mixed internally with the UFX DSP mixer and routed to different outputs etc..
So im wondering is this hard to do ? In order for the UFX to playback pre recorded tracks do they need to be in the same interleave format it records in ? Or can they remain as seperate .WAV files exported from a DAW ? if they need to be interleaved format is this easy enough to create from most common DAW programs ? If anyone knows any pitfalls i might encounter please let me know.
