Topic: Reaktor 5 Audio configuration help
Hi, does anybody know how to route Reaktor 5.8 into the HDSPe/totalmix so I can route the audio signal in totalmix to the masterout.. I had no problem doing this with my old motu 828mk3 within Reaktor, meaning by using the REAKTOR: File > Audio and MIDI Settings … > Audio or Routing. The problem isn't the routing within the totalmix it's actually getting the signal to appear within  a totalmix channel.  When I open the routing tab within the audio and midi settings there is no drop down option to choose my main output source just an option to select.
Reaktor 1    AIO Analog 1
Reaktor 2    AIO Analog 2
The only other option is "Not connected".  I've tried all the channels within the totalmix and don't seem to be getting any signal anywhere on the mixer. My main outs are ''AN 1 and AN 2'' while using FL Studio / Winamp everything works fine.  Any suggestions on this matter would be greatly appreciated. Just so you know I'm running the current flash and driver updates for my RME card and...
Windows 7
HDSPe AIO w/ balancedbreakout cable
RME AI4S192 AIO and RME AO4S192 AIO
Asio Hammerfall DSP and yes, i've also tried the Asio4All option
Thanks,
JR
Re: Reaktor 5 Audio configuration help
Maybe this question is better put into the NI forums?
