Topic: MIX EQ/compressor - monitor cable question
Greetings!
My questions:
1.Is there a way to apply EQ/compressors to my mix? I can't do that on my software channels in Totalmix, only input and output. If i route them to the outputs, then I can't monitor them, because you can only hear 1 stereo output channel via main.
2.What is the best way to mix? Routing the DAW channels to all software Totalmix channels, or mix them to 1 software channel? I read in the manual that 30 channels are supported but I see only 18 (analog+ADAT etc), why?
3.What does AS1/2 mean?
4.What's the best way to monitor the output? Connect analog TRS to my physical mixer? SDPIF and convert to RCA? Is there a special setting I have to enable to hear via SDPIF/RCA?
Too may questions I know :-). Many, many thanks!
