1 (edited by Rapido 2013-02-14 15:32:14)
Topic: Babyface and headphones amp
hello,
just got a new Babyface and i'm really happy with it but... i would like to have much volume with my Akg K702 so i'm looking to buy an external headphone amp.
Well, my questions is: is it correct to connect Babyface's headphone out to an external amp (like Pro-Ject HEAD BOX 2) using a 1/4 TRS to RCA cable?
I know this has been discussed a lot but i can't really find this specific answer
thx in advance
Re: Babyface and headphones amp
AKG K702 isn't particularly high impedance can (I have K701, which is essentially the same), maybe around 50 or 80 ohm, I don't hink you need an external headphone amp.
i can live even with the actual volume but it happen, when i'm working in some specific situation, that i need to boost the volume to better listen some low level stuff, i don't have any problem when i'm listening to mastered music.
Anyway, thx for your reply but it not answer my question
Rapido wrote:
hello,
thx in advance
i have the AKG K701 and I sought not only more volume, but just better overall sound from the Babyface headphone jack.  so i bought this
http://www.jdslabs.com/item.php?fetchitem=O2Full
and a custom made short 1/4 TRS male to 1/8" TRS male cable from Blue Jean Cables
it's a night and day improvement IMHO
The impedance rating alone of the AKG K and Q series is not truly indicative of their power requirements and responsiveness, and the 30 ohm output rating of the Babyface headphone jack confounds many headphone nerds.   This is RME's forum however, so we shouldn't go too far into this.   Let's just say that not everyone agrees what the correct output impedance for a headphone jack is.
http://nwavguy.blogspot.com/2011/02/hea … ained.html
http://nwavguy.blogspot.com/2011/02/hea … dance.html
happy reading and audio enjoyment
--jay
thx for the suggestion, really appreciate
The k701, k612, k712, and k702s all use the same capsule, the DKK45, so essentially they should have the same impedance and other performance specs. The impedance is 62 ohms. I've read that 50 is the official cutoff for "low impedance" headphones. I am also curious as to whether the Babyface Pro will drive the cans adequately with relatively flat sound adequate for monitoring and mixing.
