Topic: Clocking UFX over ADAT. Wordclock sync won't go above 48kHz
When using a Mytek 8x192 as a 96kHz master clock via ADAT1, the UFX will correctly detect 96kHz as the sample rate, but the "Input Status" section won't reflect anything above 48kHz for sync.
Is anyone able to receive WC sync at full 96kHz over ADAT?  Is this a limitation of the format, even with s/mux?  Recording and playback sounds fine at 96kHz, but I want to make sure I'm using best practices.
Thanks.
Re: Clocking UFX over ADAT. Wordclock sync won't go above 48kHz
Yes.
Fair enough.  Thanks!
