Topic: How to get SPDIF output from the HDSPe AIO souncard
I recently bought a HDSPe AIO soundcard for some testing purpose.
I would like to get a 192KHz SPDIF output from the soundcard.
In order to check the functionality of the soundcard, i am giving a digital output through a DVD player to the SPDIF input of the soundcard, using Digital Adaptor cable.
I am able to receive the analog output of it, through the Analog Adaptor Cable, but i do not get an SPDIF output.
I do have a SPDIF receiver, which receives the digital data and converts it back into analog outputs. So the working of this setup has been confirmed, when i directly route the DVD player digital output to SPDIF receiver, as i am able to get an analog output with this setup.
So i have two queires as listed below:
1. How to get SPDIF output signal through soundcard?
2. Does the sampling frequency of the SPDIF output will depend on the source DVD sampling rate or i can make the changes in he HDSP settings to output the signal at any desired sampling rate?
Kindly let me know the above details.
Thanks,
Harshit
