Topic: FF800 Slaved via ADAT into FF-UFX
Up until now, my main audio interface has been a Fireface 800 and it has served me admirably. I could not want for better sound quality. Now that I have recently acquired a Fireface UFX, my plan is to setup my FF800 to run standalone and slave it via ADAT into my UFX, in order to add 8 more AD and 8 more DA channels to the UFX.
I am trying to figure out if the round trip latency through the FF800 AD + DA and ADAT in addition to the FF-UFX USB safety buffer will be an issue. If I am adding things up correctly, at 44.1 KHz sample rate, the H/W RTL of the FF800 analog and UFX USB would be .98 msec FF800 AD + .63 msec FF800 DA + .725 msec FF-UFX USB = 2.34 msec H/W latency. Are there any other H/W delays that come into play when using the FF800 as an ADAT unit?
How does the 2.34 msec H/W latency of the FF800 used as an ADAT unit compare to other ADAT converter interfaces like the ADI-8 DS Mk III? I could not find any specs on the ADI-8 DS Mk III for RTL other than the RME product page says "Low latency conversion: less than 12 samples delay". I'm not clear if that is 12 samples delay each on the AD and the DA or total, but anyway it is apparently less than the FF800 used as an ADAT unit.
For quite a long time, I have been using an analog mixer paralleled with my inputs to my audio interface to create monitor mixes here in my studio. Now that I have the UFX, my plan is to get rid of the analog mixer and generate all of my monitor mixes using the UFX.
I'm interested in hearing comments from people here on this forum as to how much would the H/W latency of the digital mixers (FF800 and FF-UFX) affect the monitoring mix in the setup I have planned?
