Topic: hdspmixer necessary for HDSP 9652
Hello all,
I have an RME HDSP 9652 PCI card[1] installed unter Ubuntu 12.04.1[2], kernel 3.2.0-33-generic-pae [3].
There's two things I need help with:
1. Is there a way to use the ADAT outputs of the card under "pure" ALSA, without jackd? For now I start up jackd and get system:playback_1 through system:playback_26 but I would very much like to just use (mplayer-style) hw:0.0 through hw:0.25 - any ideas/any alsa config files that would help me with this?
2. Using jack, I need to start up hdspmixer to hear any sound - without starting it I see all the jackd outputs, all the jackd inputs, the routing is ok - but no sound. Starting up hdspmixer gives me sound on my Behringer ADAT-to-analog outputs.
I suppose hdspmixer sets the volume - I'd like to do this without X and, most important, without user interaction. So can I copy/activate the volume settings the same way hdspmixer does from the commandline?
Thanks for your help,
Christian.
[1]: 01:0a.0 Multimedia audio controller: Xilinx Corporation RME Hammerfall DSP (rev 6c)
[2]: Ubuntu 12.04.1 LTS
[3]: Linux music 3.2.0-33-generic-pae #52-Ubuntu SMP Thu Oct 18 16:39:21 UTC 2012 i686 athlon i386 GNU/Linux
