Topic: Babyface questions
Hello there,
Just got this babyface. Mostly problem free but I do have a few issues I don't understand how to setup:
1) ADAT Inputs/Outputs are not aligned in Core Audio. i.e. Input 3 in core audio is ADAT 1 but Output 5 is ADAT 1. With this difference I cannot easily setup insert in pro tools using an 8 channel converter. Is there any remedy to this? (to align all ADAT inputs to the same number as outputs?)
2) PH 3/4 has no dedicated fader? So I'm not quite understanding this. The headphone output on the babyface itself is coupled to Analog 1/2 output? Where can I control the headphone volume apart from using the jogwheel? And the headphone output on the breakout cable is 3/4 but it has no dedicated fader control? Does the jogwheel control both?
Jantzen
