Topic: RME MADI PCI SSL Alpha SX 88.2/96k Matthias Jeff HELP!
Windows 7 64bit
Sequoia V12.2.1.180
RME WDM V 3.32
Installed Cards: PCI- Madi & AES 32; PCIe AES 32
System Clock: SR 88.2 or 96k (would perfer 96k)
Master: MYTEK 8x192 > BNC OUT > Alpha LInk WC IN
>RME MADI PCI IN (Terminated)
>AES 32 PCI>AES32 PCIe
Set-up: Mytek AES out> To Alpha IN AES 1-8
Madi I/O: Fiber to RME
Alpha will lock with Sync for various time amounts, then drop out.
I've been able to hold lock for upto ~5 Minutes then drops..
At times, depending on the settings I've tried, it will even go completely DARK. No LEDs lit whatsoever.
I wish to have the AlphaLink run 1-24 Analog; 25-32 Digital from Mytek.
This works fine running Alpha Link as internal clock, but not using the Mytek as Master. This is how I want the System to be clocked. Mytek as Master.
RME Hammer Settings: Auto & TMS ( I've tried every combintation) ? What is correct?
WDM 32
Clock Source: Word
Madi In: Opti
Madi Out: 64/32/16
88.2/96: 96k Frame
WC Out: Unchecked
Madi Input Status shows: 32ch 96k frame 88.2 Optical
Sync Check: Varies from Sync/Sync Sometimes Madi "Blinks"
Settings Alpha Link
P1: All off Except 5 (I've tried this on and off) AES channel Status On/Off
P2: Only 4,5,6,7, ON (tried this off as well) Sample Rate Converters
P3: All On.. (tried this all off as well) this is the stock setting. Deals with Control Host, and External Clock VIA Madi or Video Sync.
Please help, I've spent countless hours trying to get this right. I'm assuming this is some ALPHA link Issue, but you guys always seem to be the most informed.
Many thanks!
