Topic: fireface ucx
hi- need someone's help- I can not get midi to work - vers 3.14 v.022 driver 3.14
mac 10.6.8 processor 2x3 ghz quad core intel xeon memory 6 gb 800 mhz
Mike
RME User Forum → FireWire & USB series → fireface ucx
Mike
More details, please...
using logic 9.1.8 - midi controller is korg prophecy - i have my flashing amber in2 light on the the front of the unit doing its thing (if i hit keys on the key board i can see that the midi light respondes the same)- i go into the midi setup, put it in test, hit the triangle facing down on the rme icon and i see the midi out2 light flash on the unit. there is no response when i hit the in2 triangle .. however it keeps flashing steady. - i was using presonus and everything was working fine.
