+1 for this one.
I believe this would require a setting inside UFX for selecting the midi clock source. Would definately be cool in standalone too, but how about syncing to daw? Would this require a new virtual port in TMFX, or could the clock be picked up directly from UFX midi out, as I'm already sending midi clock to other gear.. ? Just wondering.. HeadScratch
Very exited to see the UFX/UCX being developed even further. I'm actually going buy another UFX when I can afford one. (And if the new midi functions are added.) Don't really like having to constantly unscrew and screw my only UFX back to my rack, for I want to use it in every situation.
One more (unrelated) question: Would it be possible to replace the usb-port of UFX myself, or maybe have someone in Finland do it for me? Any RME repair here? Sending the unit to Germany (thomann) and back would take a few weeks, and I need my unit pretty much every day.
I had a usb cable stuck in my UFX, and when I pulled it out, the pin on the other side with some of the metal around it came off. The USB connection works fine, the cable is just very loose and might get disconnected easily. (I'm using FW connection so I'm fine for now, but I would still like to get it fixed one day)
