Topic: 2 9632 simutaneously?
I have a dumb question, I´m happy with my 9632, but I need more ADATs, so can I buy another 9632 and use them together? Thanks for your help!
Re: 2 9632 simutaneously?
yes, you can use two cards, the driver theoretically supports up to six - that is, if you are referring to the HDSP 9632. But even the older Hammerfall card (9636) will do this, if that is what you have and if you can still trace a second one.
To properly sync two Digi9636 cards, can one use the 9-pin SPDIF cable to connect the two together for proper sync?
5
Sure.
