Topic: Hdspe AES & Cable question (to Stereo DAC connection)
- Please, sorry for my bad Inglish, i'm French -
I've just buy and installed my Hdspe AES Card. I play virtual piano like "VSL Vienna imperial" I want to connect the Rme card to my DAC, a Mytek 192 DSD, wich have a AES input:
Because of noise consideration, the PC is not in the same room that the piano. So, i need a cable of about 10m. Do you advise me to prefer a long AES cable beetween the PC and the DAC and a short Analog cable beetween the DAC and the Amplifier, or the contrary ? (Short AES/Long Analog) Another solution is a short Db25-4m4fAES cable then a long Single AES cable.
There are so many AES cables on the net that makes me lost...
Can i use any DB25->4m4fAES XLR cable ? or is there a DB25 type to respect in particular, such "tascam type" or other thing ?
I found only cables that looks "cheap", like this one for exemple:
http://www.thomann.de/fr/rme_bo25mxlr4m4fr.htm
The cables seems so little !
Is this other cable OK ? it's a D25->4m4f XLR, but it's writte "compatible YAMAHA/MACKIE" (so not tascam ? rme ?)
http://www.thomann.de/fr/mutec_d25xlr8i … ticore.htm
Or this one (Cost a little much, maybe better ?)
http://www.musikia.com/fr/klotz-sub-d-2 … p,M0019204
I saw on this forum a post about this another cable:
http://www.mogamicable.com/category/pro … 25-XLR.php
it seems good, but i don't see any price (?!) and i don't know if i can buy it in France:
So, finally, which cable do you advise me ? Thx a lot for your help, i really need it !
